how to solve problem active check update from started to fail (SSL_write() timed out)
  • solution
    • Jun 2020
    • 271
    I have Zabbix Server monitoring more than 1000 hosts and recently some hosts added are not sending data to the server.
    the message in the log is this:
    active check configuration update from [server.no-ip.org:10051] started to fail (SSL_write() timed out)
    the message in the log from server:
    cannot send list of active checks to "200.16.161.26": host [USS-NotebookBerro] not found
    Does anyone know what can cause this problem and how to resolve it?
    ***happens with some hosts and others don't
    Zabbix Server: 5.2.6
    O.S.: CentOS 8.3 **SELINUX Disabled
    Host:
    Zabbix Agent: tested with 5.01 and 5.2.6
    O.S.: Windows 10 20H2
    Connection: PSK **checked and is correct in host and in server
    Log Agent Verb 4:
    10528:20210514:104240.016 Starting Zabbix Agent [USS-NotebookBerro]. Zabbix 5.2.6 (revision 798506596c).
    10528:20210514:104240.020 **** Enabled features ****
    10528:20210514:104240.025 IPv6 support: YES
    10528:20210514:104240.029 TLS support: YES
    10528:20210514:104240.033 **************************
    10528:20210514:104240.037 using configuration file: C:\zabbix\conf\zabbix_agentd.conf
    10528:20210514:104240.041 In init_collector_data()
    10528:20210514:104240.045 logical CPU count 4
    10528:20210514:104240.049 End of init_collector_data()
    10528:20210514:104240.055 In init_perf_collector()
    10528:20210514:104240.058 In init_builtin_counter_indexes()
    10528:20210514:104240.062 In get_all_counter_names()
    10528:20210514:104240.106 End of get_all_counter_names()
    10528:20210514:104240.238 End of init_builtin_counter_indexes():SUCCEED
    10528:20210514:104240.242 In set_object_names()
    10528:20210514:104240.467 In get_all_counter_names()
    10528:20210514:104240.473 End of get_all_counter_names()
    10528:20210514:104240.477 In get_all_counter_names()
    10528:20210514:104240.486 End of get_all_counter_names()
    10528:20210514:104240.525 End of set_object_names():SUCCEED
    10528:20210514:104240.529 End of init_perf_collector():SUCCEED
    10528:20210514:104240.534 OpenSSL library (version OpenSSL 1.1.1k 25 Mar 2021) initialized
    10528:20210514:104240.537 agent #0 started [main process]
    8520:20210514:104240.542 agent #1 started [collector]
    3080:20210514:104240.545 agent #2 started[listener #1]
    6552:20210514:104240.550 agent #3 started[listener #2]
    7784:20210514:104240.554 agent #4 started[listener #3]
    1208:20210514:104240.558 agent #5 started [active checks #1]
    8520:20210514:104240.562 In init_cpu_collector()
    3080:20210514:104240.566 In zbx_tls_init_child()
    6552:20210514:104240.570 In zbx_tls_init_child()
    7784:20210514:104240.574 In zbx_tls_init_child()
    1208:20210514:104240.578 In zbx_tls_init_child()
    8520:20210514:104240.582 In get_counter_name() pdhIndex:238
    3080:20210514:104240.586 zbx_tls_init_child() loaded PSK identity "zapsk"
    6552:20210514:104240.590 zbx_tls_init_child() loaded PSK identity "zapsk"
    7784:20210514:104240.594 zbx_tls_init_child() loaded PSK identity "zapsk"
    1208:20210514:104240.601 zbx_tls_init_child() loaded PSK identity "zapsk"
    8520:20210514:104240.604 End of get_counter_name():SUCCEED
    3080:20210514:104240.608 zbx_tls_init_child() loaded PSK from file "C:\zabbix\conf\agentkey.psk"
    6552:20210514:104240.613 zbx_tls_init_child() loaded PSK from file "C:\zabbix\conf\agentkey.psk"
    7784:20210514:104240.617 zbx_tls_init_child() loaded PSK from file "C:\zabbix\conf\agentkey.psk"
    1208:20210514:104240.621 zbx_tls_init_child() loaded PSK from file "C:\zabbix\conf\agentkey.psk"
    8520:20210514:104240.624 In get_counter_name() pdhIndex:6
    3080:20210514:104240.628 zbx_tls_init_child() PSK ciphersuites: TLS_CHACHA20_POLY1305_SHA256 TLS_AES_128_GCM_SHA256 ECDHE-PSK-AES128-CBC-SHA256 ECDHE-PSK-AES128-CBC-SHA PSK-AES128-GCM-SHA256 PSK-AES128-CCM8 PSK-AES128-CCM PSK-AES128-CBC-SHA256 PSK-AES128-CBC-SHA
    6552:20210514:104240.632 zbx_tls_init_child() PSK ciphersuites: TLS_CHACHA20_POLY1305_SHA256 TLS_AES_128_GCM_SHA256 ECDHE-PSK-AES128-CBC-SHA256 ECDHE-PSK-AES128-CBC-SHA PSK-AES128-GCM-SHA256 PSK-AES128-CCM8 PSK-AES128-CCM PSK-AES128-CBC-SHA256 PSK-AES128-CBC-SHA
    7784:20210514:104240.636 zbx_tls_init_child() PSK ciphersuites: TLS_CHACHA20_POLY1305_SHA256 TLS_AES_128_GCM_SHA256 ECDHE-PSK-AES128-CBC-SHA256 ECDHE-PSK-AES128-CBC-SHA PSK-AES128-GCM-SHA256 PSK-AES128-CCM8 PSK-AES128-CCM PSK-AES128-CBC-SHA256 PSK-AES128-CBC-SHA
    1208:20210514:104240.640 zbx_tls_init_child() PSK ciphersuites: TLS_CHACHA20_POLY1305_SHA256 TLS_AES_128_GCM_SHA256 ECDHE-PSK-AES128-CBC-SHA256 ECDHE-PSK-AES128-CBC-SHA PSK-AES128-GCM-SHA256 PSK-AES128-CCM8 PSK-AES128-CCM PSK-AES128-CBC-SHA256 PSK-AES128-CBC-SHA
    8520:20210514:104240.644 End of get_counter_name():SUCCEED
    3080:20210514:104240.648 End of zbx_tls_init_child()
    6552:20210514:104240.652 End of zbx_tls_init_child()
    7784:20210514:104240.656 End of zbx_tls_init_child()
    1208:20210514:104240.660 End of zbx_tls_init_child()
    8520:20210514:104240.665 In add_perf_counter() counter:'\Processador(_Total)\% tempo de processador' interval:900
    1208:20210514:104240.669 In init_active_metrics()
    8520:20210514:104240.673 add_perf_counter(): PerfCounter '\Processador(_Total)\% tempo de processador' successfully added
    1208:20210514:104240.677 buffer: first allocation for 100 elements
    8520:20210514:104240.681 End of add_perf_counter(): SUCCEED
    1208:20210514:104240.686 End of init_active_metrics()
    8520:20210514:104240.690 In add_perf_counter() counter:'\Processador(0)\% tempo de processador' interval:900
    8520:20210514:104240.694 add_perf_counter(): PerfCounter '\Processador(0)\% tempo de processador' successfully added
    1208:20210514:104240.698 In send_buffer() host:'solutionsp.no-ip.org' port:10051 entries:0/100
    8520:20210514:104240.702 End of add_perf_counter(): SUCCEED
    1208:20210514:104240.706 End of send_buffer():SUCCEED
    8520:20210514:104240.711 In add_perf_counter() counter:'\Processador(1)\% tempo de processador' interval:900
    1208:20210514:104240.715 In refresh_active_checks() host:'solutionsp.no-ip.org' port:10051
    8520:20210514:104240.719 add_perf_counter(): PerfCounter '\Processador(1)\% tempo de processador' successfully added
    8520:20210514:104240.724 End of add_perf_counter(): SUCCEED
    8520:20210514:104240.728 In add_perf_counter() counter:'\Processador(2)\% tempo de processador' interval:900
    8520:20210514:104240.732 add_perf_counter(): PerfCounter '\Processador(2)\% tempo de processador' successfully added
    8520:20210514:104240.736 End of add_perf_counter(): SUCCEED
    8520:20210514:104240.740 In add_perf_counter() counter:'\Processador(3)\% tempo de processador' interval:900
    8520:20210514:104240.745 add_perf_counter(): PerfCounter '\Processador(3)\% tempo de processador' successfully added
    8520:20210514:104240.749 End of add_perf_counter(): SUCCEED
    8520:20210514:104240.753 In get_counter_name() pdhIndex:2
    8520:20210514:104240.757 End of get_counter_name():SUCCEED
    8520:20210514:104240.761 In get_counter_name() pdhIndex:44
    8520:20210514:104240.765 End of get_counter_name():SUCCEED
    8520:20210514:104240.769 In add_perf_counter() counter:'\Sistema\Comprimento da fila de processador' interval:900
    8520:20210514:104240.775 add_perf_counter(): PerfCounter '\Sistema\Comprimento da fila de processador' successfully added
    8520:20210514:104240.779 End of add_perf_counter(): SUCCEED
    8520:20210514:104240.783 End of init_cpu_collector():SUCCEED
    8520:20210514:104240.787 In collect_perfstat()
    8520:20210514:104240.792 End of collect_perfstat()
    1208:20210514:104240.891 In zbx_tls_connect(): psk_identity:"zapsk"
    1208:20210514:104240.896 zbx_psk_client_cb() requested PSK identity "zapsk"
    1208:20210514:104241.078 End of zbx_tls_connect():SUCCEED (established TLSv1.3 TLS_CHACHA20_POLY1305_SHA256)
    1208:20210514:104241.083 sending [{"request":"active checks","host":"USS-NotebookBerro"}]
    1208:20210514:104241.087 active check configuration update from [server.no-ip.org:10051] started to fail (SSL_write() timed out)
    1208:20210514:104241.091 End of refresh_active_checks():FAIL
    1208:20210514:104241.096 In process_active_checks() server:'server.no-ip.org' port:10051
    1208:20210514:104241.100 End of process_active_checks()
    1208:20210514:104241.104 In get_min_nextcheck()
    1208:20210514:104241.109 End of get_min_nextcheck():-1
    1208:20210514:104241.113 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104241.117 End of send_buffer():SUCCEED
    8520:20210514:104241.806 In collect_perfstat()
    8520:20210514:104241.812 End of collect_perfstat()
    1208:20210514:104242.127 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104242.132 End of send_buffer():SUCCEED
    8520:20210514:104242.817 In collect_perfstat()
    8520:20210514:104242.823 End of collect_perfstat()
    1208:20210514:104243.139 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104243.144 End of send_buffer():SUCCEED
    8520:20210514:104243.829 In collect_perfstat()
    8520:20210514:104243.835 End of collect_perfstat()
    1208:20210514:104244.162 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104244.166 End of send_buffer():SUCCEED
    8520:20210514:104244.844 In collect_perfstat()
    8520:20210514:104244.850 End of collect_perfstat()
    1208:20210514:104245.186 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104245.190 End of send_buffer():SUCCEED
    8520:20210514:104245.860 In collect_perfstat()
    8520:20210514:104245.866 End of collect_perfstat()
    1208:20210514:104246.209 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104246.214 End of send_buffer():SUCCEED
    8520:20210514:104246.878 In collect_perfstat()
    8520:20210514:104246.884 End of collect_perfstat()
    1208:20210514:104247.232 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104247.237 End of send_buffer():SUCCEED
    8520:20210514:104247.892 In collect_perfstat()
    8520:20210514:104247.898 End of collect_perfstat()
    1208:20210514:104248.247 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104248.252 End of send_buffer():SUCCEED
    8520:20210514:104248.905 In collect_perfstat()
    8520:20210514:104248.912 End of collect_perfstat()
    1208:20210514:104249.270 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104249.275 End of send_buffer():SUCCEED
    8520:20210514:104249.928 In collect_perfstat()
    8520:20210514:104249.935 End of collect_perfstat()
    1208:20210514:104250.293 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104250.298 End of send_buffer():SUCCEED
    8520:20210514:104250.954 In collect_perfstat()
    8520:20210514:104250.960 End of collect_perfstat()
    1208:20210514:104251.305 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104251.309 End of send_buffer():SUCCEED
    8520:20210514:104251.969 In collect_perfstat()
    8520:20210514:104251.974 End of collect_perfstat()
    1208:20210514:104252.321 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104252.325 End of send_buffer():SUCCEED
    8520:20210514:104252.981 In collect_perfstat()
    8520:20210514:104252.989 End of collect_perfstat()
    1208:20210514:104253.344 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104253.349 End of send_buffer():SUCCEED
    8520:20210514:104253.996 In collect_perfstat()
    8520:20210514:104254.002 End of collect_perfstat()
    1208:20210514:104254.356 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104254.361 End of send_buffer():SUCCEED
    8520:20210514:104255.014 In collect_perfstat()
    8520:20210514:104255.020 End of collect_perfstat()
    1208:20210514:104255.374 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104255.379 End of send_buffer():SUCCEED
    8520:20210514:104256.035 In collect_perfstat()
    8520:20210514:104256.041 End of collect_perfstat()
    1208:20210514:104256.386 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104256.391 End of send_buffer():SUCCEED
    8520:20210514:104257.049 In collect_perfstat()
    8520:20210514:104257.055 End of collect_perfstat()
    1208:20210514:104257.404 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104257.408 End of send_buffer():SUCCEED
    8520:20210514:104258.060 In collect_perfstat()
    8520:20210514:104258.066 End of collect_perfstat()
    1208:20210514:104258.423 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104258.428 End of send_buffer():SUCCEED
    8520:20210514:104259.074 In collect_perfstat()
    8520:20210514:104259.080 End of collect_perfstat()
    1208:20210514:104259.436 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104259.440 End of send_buffer():SUCCEED
    8520:20210514:104300.090 In collect_perfstat()
    8520:20210514:104300.095 End of collect_perfstat()
    1208:20210514:104300.452 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104300.456 End of send_buffer():SUCCEED
    8520:20210514:104301.105 In collect_perfstat()
    8520:20210514:104301.111 End of collect_perfstat()
    1208:20210514:104301.470 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104301.475 End of send_buffer():SUCCEED
    8520:20210514:104302.127 In collect_perfstat()
    8520:20210514:104302.133 End of collect_perfstat()
    1208:20210514:104302.489 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104302.493 End of send_buffer():SUCCEED
    8520:20210514:104303.146 In collect_perfstat()
    8520:20210514:104303.152 End of collect_perfstat()
    1208:20210514:104303.507 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104303.511 End of send_buffer():SUCCEED
    8520:20210514:104304.165 In collect_perfstat()
    8520:20210514:104304.171 End of collect_perfstat()
    1208:20210514:104304.527 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104304.534 End of send_buffer():SUCCEED
    8520:20210514:104305.176 In collect_perfstat()
    8520:20210514:104305.183 End of collect_perfstat()
    1208:20210514:104305.541 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104305.546 End of send_buffer():SUCCEED
    8520:20210514:104306.188 In collect_perfstat()
    8520:20210514:104306.195 End of collect_perfstat()
    1208:20210514:104306.565 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104306.570 End of send_buffer():SUCCEED
    8520:20210514:104307.215 In collect_perfstat()
    8520:20210514:104307.221 End of collect_perfstat()
    1208:20210514:104307.577 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104307.582 End of send_buffer():SUCCEED
    8520:20210514:104308.237 In collect_perfstat()
    8520:20210514:104308.242 End of collect_perfstat()
    1208:20210514:104308.596 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104308.603 End of send_buffer():SUCCEED
    8520:20210514:104309.260 In collect_perfstat()
    8520:20210514:104309.268 End of collect_perfstat()
    1208:20210514:104309.613 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104309.618 End of send_buffer():SUCCEED
    8520:20210514:104310.284 In collect_perfstat()
    8520:20210514:104310.290 End of collect_perfstat()
    1208:20210514:104310.636 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104310.641 End of send_buffer():SUCCEED
    8520:20210514:104311.304 In collect_perfstat()
    8520:20210514:104311.310 End of collect_perfstat()
    1208:20210514:104311.654 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104311.658 End of send_buffer():SUCCEED
    8520:20210514:104312.323 In collect_perfstat()
    8520:20210514:104312.329 End of collect_perfstat()
    1208:20210514:104312.670 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104312.674 End of send_buffer():SUCCEED
    8520:20210514:104313.349 In collect_perfstat()
    8520:20210514:104313.356 End of collect_perfstat()
    1208:20210514:104313.689 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104313.693 End of send_buffer():SUCCEED
    8520:20210514:104314.380 In collect_perfstat()
    8520:20210514:104314.386 End of collect_perfstat()
    1208:20210514:104314.709 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104314.714 End of send_buffer():SUCCEED
    8520:20210514:104315.397 In collect_perfstat()
    8520:20210514:104315.404 End of collect_perfstat()
    1208:20210514:104315.723 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104315.728 End of send_buffer():SUCCEED
    8520:20210514:104316.418 In collect_perfstat()
    8520:20210514:104316.424 End of collect_perfstat()
    1208:20210514:104316.744 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104316.749 End of send_buffer():SUCCEED
    8520:20210514:104317.429 In collect_perfstat()
    8520:20210514:104317.435 End of collect_perfstat()
    1208:20210514:104317.762 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104317.766 End of send_buffer():SUCCEED
    8520:20210514:104318.448 In collect_perfstat()
    8520:20210514:104318.453 End of collect_perfstat()
    1208:20210514:104318.776 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104318.781 End of send_buffer():SUCCEED
    8520:20210514:104319.466 In collect_perfstat()
    8520:20210514:104319.472 End of collect_perfstat()
    1208:20210514:104319.794 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104319.799 End of send_buffer():SUCCEED
    8520:20210514:104320.486 In collect_perfstat()
    8520:20210514:104320.492 End of collect_perfstat()
    1208:20210514:104320.815 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104320.820 End of send_buffer():SUCCEED
    8520:20210514:104321.511 In collect_perfstat()
    8520:20210514:104321.518 End of collect_perfstat()
    1208:20210514:104321.831 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104321.835 End of send_buffer():SUCCEED
    8520:20210514:104322.531 In collect_perfstat()
    8520:20210514:104322.537 End of collect_perfstat()
    1208:20210514:104322.842 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104322.850 End of send_buffer():SUCCEED
    8520:20210514:104323.549 In collect_perfstat()
    8520:20210514:104323.556 End of collect_perfstat()
    1208:20210514:104323.866 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104323.870 End of send_buffer():SUCCEED
    8520:20210514:104324.574 In collect_perfstat()
    8520:20210514:104324.581 End of collect_perfstat()
    1208:20210514:104324.887 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104324.892 End of send_buffer():SUCCEED
    8520:20210514:104325.586 In collect_perfstat()
    8520:20210514:104325.592 End of collect_perfstat()
    1208:20210514:104325.911 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104325.916 End of send_buffer():SUCCEED
    8520:20210514:104326.608 In collect_perfstat()
    8520:20210514:104326.614 End of collect_perfstat()
    1208:20210514:104326.933 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104326.937 End of send_buffer():SUCCEED
    8520:20210514:104327.628 In collect_perfstat()
    8520:20210514:104327.634 End of collect_perfstat()
    1208:20210514:104327.945 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104327.950 End of send_buffer():SUCCEED
    8520:20210514:104328.645 In collect_perfstat()
    8520:20210514:104328.651 End of collect_perfstat()
    1208:20210514:104328.962 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104328.966 End of send_buffer():SUCCEED
    8520:20210514:104329.668 In collect_perfstat()
    8520:20210514:104329.673 End of collect_perfstat()
    1208:20210514:104329.973 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104329.977 End of send_buffer():SUCCEED
    8520:20210514:104330.691 In collect_perfstat()
    8520:20210514:104330.700 End of collect_perfstat()
    1208:20210514:104330.992 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104330.996 End of send_buffer():SUCCEED
    8520:20210514:104331.711 In collect_perfstat()
    8520:20210514:104331.717 End of collect_perfstat()
    1208:20210514:104332.011 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104332.018 End of send_buffer():SUCCEED
    8520:20210514:104332.737 In collect_perfstat()
    8520:20210514:104332.743 End of collect_perfstat()
    1208:20210514:104333.023 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104333.028 End of send_buffer():SUCCEED
    8520:20210514:104333.750 In collect_perfstat()
    8520:20210514:104333.756 End of collect_perfstat()
    1208:20210514:104334.041 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104334.046 End of send_buffer():SUCCEED
    8520:20210514:104334.761 In collect_perfstat()
    8520:20210514:104334.767 End of collect_perfstat()
    1208:20210514:104335.061 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104335.066 End of send_buffer():SUCCEED
    8520:20210514:104335.778 In collect_perfstat()
    8520:20210514:104335.784 End of collect_perfstat()
    1208:20210514:104336.075 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104336.080 End of send_buffer():SUCCEED
    8520:20210514:104336.800 In collect_perfstat()
    8520:20210514:104336.806 End of collect_perfstat()
    1208:20210514:104337.090 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104337.095 End of send_buffer():SUCCEED
    8520:20210514:104337.811 In collect_perfstat()
    8520:20210514:104337.817 End of collect_perfstat()
    1208:20210514:104338.109 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104338.115 End of send_buffer():SUCCEED
    8520:20210514:104338.833 In collect_perfstat()
    8520:20210514:104338.839 End of collect_perfstat()
    1208:20210514:104339.124 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104339.131 End of send_buffer():SUCCEED
    8520:20210514:104339.844 In collect_perfstat()
    8520:20210514:104339.850 End of collect_perfstat()
    1208:20210514:104340.143 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104340.148 End of send_buffer():SUCCEED
    8520:20210514:104340.864 In collect_perfstat()
    8520:20210514:104340.882 End of collect_perfstat()
    1208:20210514:104341.167 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104341.173 End of send_buffer():SUCCEED
    1208:20210514:104341.180 In refresh_active_checks() host:'server.no-ip.org' port:10051
    1208:20210514:104341.375 In zbx_tls_connect(): psk_identity:"zapsk"
    1208:20210514:104341.380 zbx_psk_client_cb() requested PSK identity "zapsk"
    1208:20210514:104341.547 End of zbx_tls_connect():SUCCEED (established TLSv1.3 TLS_CHACHA20_POLY1305_SHA256)
    1208:20210514:104341.552 sending [{"request":"active checks","host":"USS-NotebookBerro"}]
    1208:20210514:104341.556 End of refresh_active_checks():FAIL
    1208:20210514:104341.562 In process_active_checks() server:'server.no-ip.org' port:10051
    1208:20210514:104341.567 End of process_active_checks()
    1208:20210514:104341.571 In get_min_nextcheck()
    1208:20210514:104341.576 End of get_min_nextcheck():-1
    8520:20210514:104341.891 In collect_perfstat()
    8520:20210514:104341.897 End of collect_perfstat()
    1208:20210514:104342.590 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104342.595 End of send_buffer():SUCCEED
    8520:20210514:104342.909 In collect_perfstat()
    8520:20210514:104342.915 End of collect_perfstat()
    1208:20210514:104343.601 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104343.605 End of send_buffer():SUCCEED
    8520:20210514:104343.933 In collect_perfstat()
    8520:20210514:104343.939 End of collect_perfstat()
    1208:20210514:104344.618 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104344.623 End of send_buffer():SUCCEED
    8520:20210514:104344.949 In collect_perfstat()
    8520:20210514:104344.955 End of collect_perfstat()
    1208:20210514:104345.641 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104345.646 End of send_buffer():SUCCEED
    8520:20210514:104345.963 In collect_perfstat()
    8520:20210514:104345.969 End of collect_perfstat()
    1208:20210514:104346.666 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104346.671 End of send_buffer():SUCCEED
    8520:20210514:104346.979 In collect_perfstat()
    8520:20210514:104346.984 End of collect_perfstat()
    1208:20210514:104347.684 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104347.688 End of send_buffer():SUCCEED
    8520:20210514:104347.994 In collect_perfstat()
    8520:20210514:104347.999 End of collect_perfstat()
    1208:20210514:104348.700 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104348.704 End of send_buffer():SUCCEED
    8520:20210514:104349.016 In collect_perfstat()
    8520:20210514:104349.022 End of collect_perfstat()
    1208:20210514:104349.721 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104349.725 End of send_buffer():SUCCEED
    8520:20210514:104350.040 In collect_perfstat()
    8520:20210514:104350.046 End of collect_perfstat()
    1208:20210514:104350.744 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104350.749 End of send_buffer():SUCCEED
    8520:20210514:104351.060 In collect_perfstat()
    8520:20210514:104351.066 End of collect_perfstat()
    1208:20210514:104351.758 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104351.762 End of send_buffer():SUCCEED
    8520:20210514:104352.080 In collect_perfstat()
    8520:20210514:104352.086 End of collect_perfstat()
    1208:20210514:104352.776 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104352.781 End of send_buffer():SUCCEED
    8520:20210514:104353.099 In collect_perfstat()
    8520:20210514:104353.105 End of collect_perfstat()
    1208:20210514:104353.796 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104353.808 End of send_buffer():SUCCEED
    8520:20210514:104354.125 In collect_perfstat()
    8520:20210514:104354.133 End of collect_perfstat()
    1208:20210514:104354.829 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104354.834 End of send_buffer():SUCCEED
    8520:20210514:104355.151 In collect_perfstat()
    8520:20210514:104355.157 End of collect_perfstat()
    1208:20210514:104355.839 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104355.844 End of send_buffer():SUCCEED
    8520:20210514:104356.169 In collect_perfstat()
    8520:20210514:104356.175 End of collect_perfstat()
    1208:20210514:104356.852 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104356.856 End of send_buffer():SUCCEED
    8520:20210514:104357.181 In collect_perfstat()
    8520:20210514:104357.186 End of collect_perfstat()
    1208:20210514:104357.868 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104357.873 End of send_buffer():SUCCEED
    8520:20210514:104358.195 In collect_perfstat()
    8520:20210514:104358.201 End of collect_perfstat()
    1208:20210514:104358.882 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104358.887 End of send_buffer():SUCCEED
    8520:20210514:104359.218 In collect_perfstat()
    8520:20210514:104359.224 End of collect_perfstat()
    1208:20210514:104359.891 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104359.896 End of send_buffer():SUCCEED
    8520:20210514:104400.241 In collect_perfstat()
    8520:20210514:104400.248 End of collect_perfstat()
    1208:20210514:104400.911 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104400.915 End of send_buffer():SUCCEED
    8520:20210514:104401.254 In collect_perfstat()
    8520:20210514:104401.260 End of collect_perfstat()
    1208:20210514:104401.924 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104401.929 End of send_buffer():SUCCEED
    8520:20210514:104402.279 In collect_perfstat()
    8520:20210514:104402.285 End of collect_perfstat()
    1208:20210514:104402.940 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104402.946 End of send_buffer():SUCCEED
    8520:20210514:104403.301 In collect_perfstat()
    8520:20210514:104403.307 End of collect_perfstat()
    1208:20210514:104403.954 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104403.958 End of send_buffer():SUCCEED
    8520:20210514:104404.316 In collect_perfstat()
    8520:20210514:104404.322 End of collect_perfstat()
    1208:20210514:104404.965 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104404.969 End of send_buffer():SUCCEED
    8520:20210514:104405.337 In collect_perfstat()
    8520:20210514:104405.345 End of collect_perfstat()
    1208:20210514:104405.989 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104405.993 End of send_buffer():SUCCEED
    8520:20210514:104406.360 In collect_perfstat()
    8520:20210514:104406.367 End of collect_perfstat()
    1208:20210514:104407.006 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104407.011 End of send_buffer():SUCCEED
    8520:20210514:104407.380 In collect_perfstat()
    8520:20210514:104407.386 End of collect_perfstat()
    1208:20210514:104408.030 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104408.035 End of send_buffer():SUCCEED
    8520:20210514:104408.395 In collect_perfstat()
    8520:20210514:104408.400 End of collect_perfstat()
    1208:20210514:104409.046 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104409.051 End of send_buffer():SUCCEED
    8520:20210514:104409.408 In collect_perfstat()
    8520:20210514:104409.413 End of collect_perfstat()
    1208:20210514:104410.060 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104410.065 End of send_buffer():SUCCEED
    8520:20210514:104410.427 In collect_perfstat()
    8520:20210514:104410.433 End of collect_perfstat()
    1208:20210514:104411.073 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104411.077 End of send_buffer():SUCCEED
    8520:20210514:104411.442 In collect_perfstat()
    8520:20210514:104411.448 End of collect_perfstat()
    1208:20210514:104412.084 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104412.089 End of send_buffer():SUCCEED
    8520:20210514:104412.461 In collect_perfstat()
    8520:20210514:104412.466 End of collect_perfstat()
    1208:20210514:104413.103 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104413.108 End of send_buffer():SUCCEED
    8520:20210514:104413.476 In collect_perfstat()
    8520:20210514:104413.482 End of collect_perfstat()
    1208:20210514:104414.126 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104414.131 End of send_buffer():SUCCEED
    8520:20210514:104414.494 In collect_perfstat()
    8520:20210514:104414.500 End of collect_perfstat()
    1208:20210514:104415.142 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104415.148 End of send_buffer():SUCCEED
    8520:20210514:104415.509 In collect_perfstat()
    8520:20210514:104415.515 End of collect_perfstat()
    1208:20210514:104416.165 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104416.169 End of send_buffer():SUCCEED
    8520:20210514:104416.528 In collect_perfstat()
    8520:20210514:104416.534 End of collect_perfstat()
    1208:20210514:104417.175 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104417.181 End of send_buffer():SUCCEED
    8520:20210514:104417.544 In collect_perfstat()
    8520:20210514:104417.550 End of collect_perfstat()
    1208:20210514:104418.194 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104418.198 End of send_buffer():SUCCEED
    8520:20210514:104418.563 In collect_perfstat()
    8520:20210514:104418.569 End of collect_perfstat()
    1208:20210514:104419.204 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104419.210 End of send_buffer():SUCCEED
    8520:20210514:104419.583 In collect_perfstat()
    8520:20210514:104419.589 End of collect_perfstat()
    1208:20210514:104420.217 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104420.222 End of send_buffer():SUCCEED
    8520:20210514:104420.601 In collect_perfstat()
    8520:20210514:104420.616 End of collect_perfstat()
    1208:20210514:104421.235 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104421.239 End of send_buffer():SUCCEED
    8520:20210514:104421.630 In collect_perfstat()
    8520:20210514:104421.636 End of collect_perfstat()
    1208:20210514:104422.250 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104422.254 End of send_buffer():SUCCEED
    8520:20210514:104422.649 In collect_perfstat()
    8520:20210514:104422.654 End of collect_perfstat()
    1208:20210514:104423.269 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104423.274 End of send_buffer():SUCCEED
    8520:20210514:104423.667 In collect_perfstat()
    8520:20210514:104423.673 End of collect_perfstat()
    1208:20210514:104424.293 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104424.298 End of send_buffer():SUCCEED
    8520:20210514:104424.680 In collect_perfstat()
    8520:20210514:104424.686 End of collect_perfstat()
    1208:20210514:104425.309 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104425.314 End of send_buffer():SUCCEED
    8520:20210514:104425.695 In collect_perfstat()
    8520:20210514:104425.700 End of collect_perfstat()
    1208:20210514:104426.334 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104426.338 End of send_buffer():SUCCEED
    8520:20210514:104426.708 In collect_perfstat()
    8520:20210514:104426.713 End of collect_perfstat()
    1208:20210514:104427.343 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104427.348 End of send_buffer():SUCCEED
    8520:20210514:104427.729 In collect_perfstat()
    8520:20210514:104427.735 End of collect_perfstat()
    1208:20210514:104428.366 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104428.371 End of send_buffer():SUCCEED
    8520:20210514:104428.755 In collect_perfstat()
    8520:20210514:104428.761 End of collect_perfstat()
    1208:20210514:104429.383 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104429.388 End of send_buffer():SUCCEED
    8520:20210514:104429.772 In collect_perfstat()
    8520:20210514:104429.778 End of collect_perfstat()
    1208:20210514:104430.402 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104430.407 End of send_buffer():SUCCEED
    8520:20210514:104430.792 In collect_perfstat()
    8520:20210514:104430.798 End of collect_perfstat()
    1208:20210514:104431.426 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104431.431 End of send_buffer():SUCCEED
    8520:20210514:104431.817 In collect_perfstat()
    8520:20210514:104431.822 End of collect_perfstat()
    1208:20210514:104432.441 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104432.446 End of send_buffer():SUCCEED
    8520:20210514:104432.830 In collect_perfstat()
    8520:20210514:104432.836 End of collect_perfstat()
    1208:20210514:104433.459 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104433.463 End of send_buffer():SUCCEED
    8520:20210514:104433.850 In collect_perfstat()
    8520:20210514:104433.855 End of collect_perfstat()
    1208:20210514:104434.481 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104434.486 End of send_buffer():SUCCEED
    8520:20210514:104434.876 In collect_perfstat()
    8520:20210514:104434.884 End of collect_perfstat()
    1208:20210514:104435.495 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104435.499 End of send_buffer():SUCCEED
    8520:20210514:104435.890 In collect_perfstat()
    8520:20210514:104435.897 End of collect_perfstat()
    1208:20210514:104436.511 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104436.515 End of send_buffer():SUCCEED
    8520:20210514:104436.909 In collect_perfstat()
    8520:20210514:104436.919 End of collect_perfstat()
    1208:20210514:104437.533 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104437.537 End of send_buffer():SUCCEED
    8520:20210514:104437.934 In collect_perfstat()
    8520:20210514:104437.941 End of collect_perfstat()
    1208:20210514:104438.556 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104438.560 End of send_buffer():SUCCEED
    8520:20210514:104438.948 In collect_perfstat()
    8520:20210514:104438.953 End of collect_perfstat()
    1208:20210514:104439.566 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104439.571 End of send_buffer():SUCCEED
    8520:20210514:104439.962 In collect_perfstat()
    8520:20210514:104439.968 End of collect_perfstat()
    1208:20210514:104440.583 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104440.587 End of send_buffer():SUCCEED
    8520:20210514:104440.982 In collect_perfstat()
    8520:20210514:104440.992 End of collect_perfstat()
    1208:20210514:104441.603 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104441.608 End of send_buffer():SUCCEED
    1208:20210514:104441.613 In refresh_active_checks() host:'server.no-ip.org' port:10051
    1208:20210514:104441.796 In zbx_tls_connect(): psk_identity:"zapsk"
    1208:20210514:104441.801 zbx_psk_client_cb() requested PSK identity "zapsk"
    1208:20210514:104441.969 End of zbx_tls_connect():SUCCEED (established TLSv1.3 TLS_CHACHA20_POLY1305_SHA256)
    1208:20210514:104441.973 sending [{"request":"active checks","host":"USS-NotebookBerro"}]
    1208:20210514:104441.978 End of refresh_active_checks():FAIL
    1208:20210514:104441.982 In process_active_checks() server:'server.no-ip.org' port:10051
    1208:20210514:104441.986 End of process_active_checks()
    1208:20210514:104441.991 In get_min_nextcheck()
    1208:20210514:104441.995 End of get_min_nextcheck():-1
    8520:20210514:104442.000 In collect_perfstat()
    8520:20210514:104442.005 End of collect_perfstat()
    1208:20210514:104443.004 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104443.009 End of send_buffer():SUCCEED
    8520:20210514:104443.020 In collect_perfstat()
    8520:20210514:104443.026 End of collect_perfstat()
    1208:20210514:104444.015 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104444.020 End of send_buffer():SUCCEED
    8520:20210514:104444.032 In collect_perfstat()
    8520:20210514:104444.038 End of collect_perfstat()
    1208:20210514:104445.032 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104445.037 End of send_buffer():SUCCEED
    8520:20210514:104445.049 In collect_perfstat()
    8520:20210514:104445.054 End of collect_perfstat()
    1208:20210514:104446.046 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104446.051 End of send_buffer():SUCCEED
    8520:20210514:104446.063 In collect_perfstat()
    8520:20210514:104446.069 End of collect_perfstat()
    1208:20210514:104447.066 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104447.070 End of send_buffer():SUCCEED
    8520:20210514:104447.081 In collect_perfstat()
    8520:20210514:104447.087 End of collect_perfstat()
    1208:20210514:104448.085 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104448.090 End of send_buffer():SUCCEED
    8520:20210514:104448.101 In collect_perfstat()
    8520:20210514:104448.107 End of collect_perfstat()
    1208:20210514:104449.096 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104449.101 End of send_buffer():SUCCEED
    8520:20210514:104449.127 In collect_perfstat()
    8520:20210514:104449.134 End of collect_perfstat()
    1208:20210514:104450.115 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104450.120 End of send_buffer():SUCCEED
    8520:20210514:104450.147 In collect_perfstat()
    8520:20210514:104450.153 End of collect_perfstat()
    1208:20210514:104451.132 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104451.137 End of send_buffer():SUCCEED
    8520:20210514:104451.159 In collect_perfstat()
    8520:20210514:104451.165 End of collect_perfstat()
    1208:20210514:104452.150 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104452.155 End of send_buffer():SUCCEED
    8520:20210514:104452.182 In collect_perfstat()
    8520:20210514:104452.188 End of collect_perfstat()
    1208:20210514:104453.171 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104453.176 End of send_buffer():SUCCEED
    8520:20210514:104453.203 In collect_perfstat()
    8520:20210514:104453.210 End of collect_perfstat()
    1208:20210514:104454.190 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104454.195 End of send_buffer():SUCCEED
    8520:20210514:104454.216 In collect_perfstat()
    8520:20210514:104454.221 End of collect_perfstat()
    1208:20210514:104455.207 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104455.211 End of send_buffer():SUCCEED
    8520:20210514:104455.232 In collect_perfstat()
    8520:20210514:104455.238 End of collect_perfstat()
    1208:20210514:104456.226 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104456.231 End of send_buffer():SUCCEED
    8520:20210514:104456.251 In collect_perfstat()
    8520:20210514:104456.257 End of collect_perfstat()
    1208:20210514:104457.252 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104457.258 End of send_buffer():SUCCEED
    8520:20210514:104457.269 In collect_perfstat()
    8520:20210514:104457.276 End of collect_perfstat()
    1208:20210514:104458.279 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104458.284 End of send_buffer():SUCCEED
    8520:20210514:104458.296 In collect_perfstat()
    8520:20210514:104458.301 End of collect_perfstat()
    1208:20210514:104459.300 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104459.305 End of send_buffer():SUCCEED
    8520:20210514:104459.317 In collect_perfstat()
    8520:20210514:104459.322 End of collect_perfstat()
    1208:20210514:104500.320 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104500.325 End of send_buffer():SUCCEED
    8520:20210514:104500.336 In collect_perfstat()
    8520:20210514:104500.344 End of collect_perfstat()
    1208:20210514:104501.337 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104501.342 End of send_buffer():SUCCEED
    8520:20210514:104501.358 In collect_perfstat()
    8520:20210514:104501.364 End of collect_perfstat()
    1208:20210514:104502.359 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104502.363 End of send_buffer():SUCCEED
    8520:20210514:104502.384 In collect_perfstat()
    8520:20210514:104502.390 End of collect_perfstat()
    1208:20210514:104503.374 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104503.379 End of send_buffer():SUCCEED
    8520:20210514:104503.406 In collect_perfstat()
    8520:20210514:104503.413 End of collect_perfstat()
    1208:20210514:104504.391 In send_buffer() host:'server.no-ip.org' port:10051 entries:0/100
    1208:20210514:104504.396 End of send_buffer():SUCCEED
    8520:20210514:104504.423 In collect_perfstat()
    8520:20210514:104504.429 End of collect_perfstat()
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    Active agent's Hostname configuration parameter (USS-NotebookBerro) must match the name of this host in Frontend configuration. Otherwise server will not accept its requests.
    • solution
      • Jun 2020
      • 271
      Thanks for the reply.
      But this has already been checked and the hostname in .conf is the same as the hostname in zabbix server, I have already changed it for testing and even so the problem is the same:
      • dimir
        Zabbix developer
        • Apr 2011
        • 1080
        This looks like encryption configuration problem. Could you post the appropriate part from zabbix server log file? Where this agent connects.
        • solution
          • Jun 2020
          • 271
          I changed the hostname just for testing:
          SERVER:
          Log Server:
          cat /var/log/zabbix/zabbix_server.log | grep -i 200.16.161.26
          5004:20210517:120133.970 cannot send list of active checks to "200.16.161.26": host [USSContabil-NotebookBeatriz] not found
          5004:20210517:120133.970 SSL_shutdown() with 200.16.161.26 set result code to 5:
          Print host config in attachment Click image for larger version  Name:	zapsk.PNG Views:	0 Size:	21.9 KB ID:	424750
          Log (verb default) in host:
          12068:20210517:120135.965 Starting Zabbix Agent [USSContabil-NotebookBeatriz]. Zabbix 5.2.6 (revision 798506596c).
          12068:20210517:120135.973 **** Enabled features ****
          12068:20210517:120135.978 IPv6 support: YES
          12068:20210517:120135.984 TLS support: YES
          12068:20210517:120135.989 **************************
          12068:20210517:120135.994 using configuration file: C:\zabbix\conf\zabbix_agentd.conf
          12068:20210517:120136.531 agent #0 started [main process]
          3452:20210517:120136.537 agent #2 started[listener #1]
          11772:20210517:120136.542 agent #3 started[listener #2]
          9516:20210517:120136.547 agent #5 started [active checks #1]
          8732:20210517:120136.553 agent #4 started[listener #3]
          6756:20210517:120136.558 agent #1 started [collector]
          9516:20210517:120136.912 active check configuration update from [server.no-ip.org:10051] started to fail (SSL_write() timed out)
          Host Config:
          # This is a configuration file for Zabbix agent service (Windows)
          # To get more information about Zabbix, visit http://www.zabbix.com
          ### Option: LogFile
          # Log file name for LogType 'file' parameter.
          # Mandatory: no
          # Default:
          # LogFile=
          LogFile=C:\zabbix\zabbix_log.log
          ### Option: DebugLevel
          # Specifies debug level:
          # 0 - basic information about starting and stopping of Zabbix processes
          # 1 - critical information
          # 2 - error information
          # 3 - warnings
          # 4 - for debugging (produces lots of information)
          # 5 - extended debugging (produces even more information)
          # Mandatory: no
          # Range: 0-5
          # Default:
          # DebugLevel=4
          ### Option: EnableRemoteCommands
          # Whether remote commands from Zabbix server are allowed.
          # 0 - not allowed
          # 1 - allowed
          # Mandatory: no
          # Default:
          EnableRemoteCommands=1
          ### Option: LogRemoteCommands
          # Enable logging of executed shell commands as warnings.
          # 0 - disabled
          # 1 - enabled
          # Mandatory: no
          # Default:
          LogRemoteCommands=1
          ##### Passive checks related
          ### Option: Server
          # List of comma delimited IP addresses, optionally in CIDR notation, or hostnames of Zabbix servers.
          # Incoming connections will be accepted only from the hosts listed here.
          # If IPv6 support is enabled then '127.0.0.1', '::127.0.0.1', '::ffff:127.0.0.1' are treated equally and '::/0' will allow any IPv4 or IPv6 address.
          # '0.0.0.0/0' can be used to allow any IPv4 address.
          # Example: Server=127.0.0.1,192.168.1.0/24,::1,2001:db8::/32,zabbix.domain
          # Mandatory: no
          # Default:
          # Server=
          Server=server.no-ip.org
          ##### Active checks related
          ### Option: ServerActive
          # List of comma delimited IPort (or hostnameort) pairs of Zabbix servers for active checks.
          # If port is not specified, default port is used.
          # IPv6 addresses must be enclosed in square brackets if port for that host is specified.
          # If port is not specified, square brackets for IPv6 addresses are optional.
          # If this parameter is not specified, active checks are disabled.
          # Example: ServerActive=127.0.0.1:20051,zabbix.domain,[::1]:30051,::1,[12fc::1]
          # Mandatory: no
          # Default:
          # ServerActive=
          ServerActive=server.no-ip.org
          ### Option: Hostname
          # Unique, case sensitive hostname.
          # Required for active checks and must match hostname as configured on the server.
          # Value is acquired from HostnameItem if undefined.
          # Mandatory: no
          # Default:
          # Hostname=
          Hostname=USSContabil-NotebookBeatriz
          ############ ADVANCED PARAMETERS #################
          ### Option: Timeout
          # Spend no more than Timeout seconds on processing.
          # Mandatory: no
          # Range: 1-30
          # Default:
          Timeout=30
          ### Option: Include
          # You may include individual files in the configuration file.
          # Mandatory: no
          # Default:
          # Include=
          # Include=c:\zabbix\zabbix_agentd.userparams.conf
          # Include=c:\zabbix\zabbix_agentd.conf.d\
          Include=c:\zabbix\zabbix_agentd.conf.d\*.conf
          ####### TLS-RELATED PARAMETERS #######
          ### Option: TLSConnect
          # How the agent should connect to server or proxy. Used for active checks.
          # Only one value can be specified:
          # unencrypted - connect without encryption
          # psk - connect using TLS and a pre-shared key
          # cert - connect using TLS and a certificate
          # Mandatory: yes, if TLS certificate or PSK parameters are defined (even for 'unencrypted' connection)
          # Default:
          TLSConnect=psk
          ### Option: TLSAccept
          # What incoming connections to accept.
          # Multiple values can be specified, separated by comma:
          # unencrypted - accept connections without encryption
          # psk - accept connections secured with TLS and a pre-shared key
          # cert - accept connections secured with TLS and a certificate
          # Default:
          TLSAccept=psk
          ### Option: TLSPSKIdentity
          # Unique, case sensitive string used to identify the pre-shared key.
          # Mandatory: no
          # Default:
          TLSPSKIdentity=zapsk
          ### Option: TLSPSKFile
          # Full pathname of a file containing the pre-shared key.
          # Mandatory: no
          # Default:
          # TLSPSKFile=
          TLSPSKFile=C:\zabbix\conf\agentkey.psk
          • dimir
            Zabbix developer
            • Apr 2011
            • 1080
            This looks like a popular case of mixing different Zabbix servers/proxies. Do you have multiple Zabbix database, server or proxy instances?
            • solution
              • Jun 2020
              • 271
              My Zabbix Server is 5.2.6 and I have 20 Proxies 5.2.4.
              But these Hosts (there are 5 on different networks) are NOT connected to a proxy.
              The connection is: Host <==> Zabbix Server
              Out of a total of 1000 Hosts, only these 5 added ones present this problem.
              Yesterday we installed a new machine on a new client with Windows 10 20H2 and used the same installer / configuration and is reporting data without problems.
              Is there a command you can run on Windows to help identify the cause?
              • pah
                • Jan 2020
                solution : Were you able to solve the problem?
                We have exactly the same problem. Only with some devices, too.
                If I use the 100% same configuration (same PSKIdentity and Key same hostname, ..) in a test VM, everything works.
                Zabbix Server: 5.0.16
                OS: Ubuntu 18.04.6
                Clients:
                Windows 10 21H1
                Zabbix Agent 5.0.17 with OpenSSL (MSI)
                • pah
                  • Jan 2020
                  I created a bug report for this: https://support.zabbix.com/browse/ZBX-20228
                  • vso
                    Zabbix developer
                    • Aug 2016
                    • 190
                    What kind of hardware are you using ? Unfortunately issue could not be reproduced locally.
                    • solution
                      • Jun 2020
                      • 271
                      As it happens only on some machines.
                      It's hard to reproduce, I've tried it on my PC and VM and the error doesn't happen.
                      In the example above, the hardware/software is:
                      Dell Laptop
                      OS: Windows 10 **Fresh Install + Windows Update updated.
                      Zabbix agent that works:
                      ONLY Zabbix Agent 3.4.6 or Zabbix Agent 2
                      • Maxburn
                        • Sep 2019
                        • 54
                        OK, I just ran into this also. Started with agent 5.0.15, moved it up to 5.0.20. While doing the upgrade it actually wiped out my client config file and windows service but not the log file. Reinstalled it copying and pasting the config from zabbix server got the client up and running again, with the exact same error.
                        This was running fine, and it just doesn't now?
                        Log attached.
                        • Maxburn
                          • Sep 2019
                          • 54
                          Actually this is worse than I thought, I just found a total of six clients doing this, out of about 55 total. They all stopped working with similar log files in above on the same day; February 20th, two days ago.
                          I just updated and rebooted the zabbix server too, Zabbix 5.0.20 on ubuntu 20.04. Also rebooted the client windows server in above post.
                          The active check I'm doing is a log count to see how many OpenVPN clients are connected and alert me on disconnections. It's kinda important to us. log.count[C:\Program Files\OpenVPN\log\openvpn-status.log,^client,ANSI,100,all,0]
                          • Maxburn
                            • Sep 2019
                            • 54
                            Solved. Updating to the beta posted below fixed me.
                            File; https://support.zabbix.com/secure/at...-openssl-2.zip
                            • solution
                              • Jun 2020
                              • 271
                              #15
                              i stopped trying and started using zabbix agent 2 as default for new installs.
                              And I started migrating the old ones too.
