high delay problems shows in dashobard
  • propusgemini@gmail.com
    • Mar 2018
    • 108
    i have a problem with the dashboard.
    non-pinging hosts are not shown in the dashobard immediatly but after a very lot time from the trigger's event.
    ICMPING losts at 19:55Click image for larger version  Name:	effective ping.JPG Views:	0 Size:	58.9 KB ID:	425013
    On dashboard 2 hours after....
    Click image for larger version  Name:	on dashboard.JPG Views:	0 Size:	17.0 KB ID:	425014
    TRIGGER:
    Click image for larger version  Name:	trigger.JPG Views:	0 Size:	47.5 KB ID:	425015
    Dashboard setting:
    Click image for larger version  Name:	dashobard setting.JPG Views:	0 Size:	56.2 KB ID:	425016
    System and my pollingstarters in zabbix config is set to 5
    Click image for larger version  Name:	Systems Pollersping 5.JPG Views:	0 Size:	28.5 KB ID:	425017
    any ideas?
    Thank you very much
    Fab
    • Mar 2018
    • 108
    Originally posted by cyber
    It is normal, if you calculate based on last 60th value.. I suppose if you ping once in 2 minutes, then this 60th value is 2h ago..
    last (<sec|#num>,<time_shift>)
    The most recent value. sec (ignored, equals #1) or #num (optional) - the Nth most recent value
    time_shift (optional) - evaluation point is moved the number of seconds back in time
    Supported value types: float, int, str, text, log
    Take note that #num works differently here than with many other functions.
    For example:
    last() is always equal to last(#1)
    last(#3) - third most recent value (not three latest values)
    Zabbix does not guarantee exact order of values if more than two values exist within one second in history.
    The #num parameter is supported since Zabbix 1.6.2.
    The time_shift parameter is supported since Zabbix 1.8.2.
    Nothing to say... only excuse me i am a newbie
      • 4996
      last (,)
      For example:
