Still can log in when LDAP authentication being disabled
  • wyang
    • Mar 2016
    • 93
    Configurations on test environment
    • default authentication: internal
    • user group admin_internal
      • Frontend access: internal
      • user1 belongs to this group
    • user group admin_ldap
      • Frontend access: LDAP
      • user2 belongs to this group
    • when LDAP authentication is configured and enabled, both users can login
    • when LDAP authentication is disabled, both users still can login
    Anything wrong in the configuration?
  • wyang
    • Mar 2016
    • 93
    We have two test environments, Zabbix 4.0 and 5.0. Tested on both, users in group admin_ldap can log in when LDAP authentication is disabled.
    • wyang
      • Mar 2016
      • 93
      The Frondend access of user group admin_ldap is explicitly defined as LDAP. The user2 was created without password.
      • wyang
        • Mar 2016
        • 93
        • user group admin_ldap was created with Frontend access method LDAP
        • user2 was created to belong to group admin_ldap without password
        • when LDAP authentication is configured and enabled, user2 can login
        • when LDAP authentication is disabled, user2 still can login
        I was wondering if user2's password was saved in zabbix from the time the user login when LDAP was enabled and thus did another test
        • user3 was created to belong to group admin_ldap without password when LDAP authentication was disabled
        • when LDAP authentication is kept being disabled, user3 can log in with LDAP password
          • 4993
          Local password is the same as in LDAP?...
