PostgreSQL plugin ping not working
  • lpossamai
    • Jun 2018
    • 119
    I have a cluster of PostgreSQL 9.2 databases, therefore I need to use the old plugin, and have setup monitoring with Zabbix and the PostgreSQL plugin. I'm monitoring 3 servers and for two of them, the
    pgsql.ping
    object is not working.
    Zabbix Server error log shows the following:
    69450:20210602:074613.276 Sending [[B]pgsql.ping[/B]["pgsql-database-02.example.com","5432","zbx_monitor","databasename"]]
    69450:20210602:074616.277 Item [pgsql-database-02.example.com:[B]pgsql.ping[/B]["{$PG.HOST}","{$PG.PORT}","{$PG.USER}","{$PG.D B}"]] error: Timeout while executing a shell script.
    69444:20210602:074616.395 zbx_substitute_functions_results() expression[4]:'{23481} = 0' => 'ERROR(Cannot evaluate function last(/pgsql-database-02.example.com/[B]pgsql.ping[/B]["{$PG.HOST}","{$PG.PORT}","{$PG.USER}","{$PG.D B}"]): item is not supported.) = 0'
    69444:20210602:074616.396 evaluate_expressions():expression [{23481} = 0] cannot be evaluated: Cannot evaluate function last(/pgsql-database-02.example.com/[B]pgsql.ping[/B]["{$PG.HOST}","{$PG.PORT}","{$PG.USER}","{$PG.D B}"]): item is not supported.
    What can I do to troubleshoot this? Also, is there a way of running
    from the server being monitored itself? or from the zabbix server?
    Thanks in advance!
