DUMMY MODULE DOESN'T APPEAR IN SCAN DIRECTORY
  • Hugogomes
    • Jun 2021
    Hello, I'm having difficulties on making modules in general to be recognize by the zabbix, but I'm trying now to make the dummy module (that already comes with zabbix) work. for some reason it does not appear in the module page in zabbix.Click image for larger version
ID:	426289 In the print above there is the path configuration for the module
    this print above show that the file is in the path
ID:	426292 in the print above shows that the dummy.so module was loaded.
    I followed the instructions in https://www.zabbix.com/documentation...oadablemodules to load the dummy module, I did the ./configure command in the root of Zabbix source tree at "/usr/local/zabbix-5.0.0" with success and after that I did the "make" command in the "/usr/local/zabbix-5.0.0/src/modules/dummy" directory in order to generate the dummy.so, after that I restarted the zabbix server and zabbix agent service, but when I went to zabbix
    What should I do in order to the module appear in zabbix?
