Zabbix CA certificates for Appliance..?!
  • tryllz
    • Jun 2021
    • 29
    1st question is, is the Zabbix Appliance web interface using Apache or Nginx ?
    2nd question is how to replace web SSL certificates for Zabbix appliance, I can see information on Zabbix Agents, Nginx, and Apache but no help for Appliance on certificates for Appliance.
    I have setup an internal Windows CA.
    Thank You
  • tryllz
    • Jun 2021
    • 29
    Originally posted by cyber
    Reading docs usually helps...
    3 FRONTEND ACCESS
    By default, access to the frontend is allowed from anywhere.
    The frontend can be accessed at http://<host>.
    This can be customized in /etc/nginx/conf.d/zabbix.conf. Nginx has to be restarted after modifying this file. To do so, log in using SSH as root user and execute:
    Cert replacement is done like in any other nginx...
    Thanks cyber
    So the idea is to have the front as Nginx (or Apache), then perform cert replaces depending on the front end used, got it, thanks..
    Also your code to be executed is not typed..
    • tryllz
      • Jun 2021
      • 29
      Sorry, got the code from the link..
        • 4996
        3 FRONTEND ACCESS
        The frontend can be accessed at http://.
