Zabbix Server is not running: the information displayed may not be current
  • FedericoCoppola97
    • Jun 2021
    Hi all,
    I have a Linux Debian 8 machine and I have Zabbix 3.4.10 installed on this Linux Machine.
    Zabbix runned without issue, but now I noted today that this Zabbix is not running.
    In the main page
    • Zabbix server is running value is NO
    • In the bottom of the page there is the warning/error message Zabbix Server is not running: the information displayed may not be current
    The service status is:
    root@xxxxxx:~# service zabbix-server status
    â— zabbix-server.service - LSB: Start zabbix-server daemon
    Loaded: loaded (/etc/init.d/zabbix-server; generated)
    Active: active (exited) since Tue 2021-06-15 12:55:32 CEST; 16min ago
    Docs: man:systemd-sysv-generator(8)
    Process: 1709 ExecStart=/etc/init.d/zabbix-server start (code=exited, status=0/SUCCESS)
    giu 15 12:55:32 networkguard systemd[1]: Starting LSB: Start zabbix-server daemon...
    giu 15 12:55:32 networkguard systemd[1]: Started LSB: Start zabbix-server daemon.
    Inside /etc/services there are properly TCP and UDP ports configured:
    zabbix-agent 10050/tcp # Zabbix Agent
    zabbix-agent 10050/udp
    zabbix-trapper 10051/tcp # Zabbix Trapper
    zabbix-trapper 10051/udp
    I do not have particular issue in log zabbix file. I have many of these message
    1496929:20210615:131112.154 enabling Zabbix agent checks on host "Zabbix server": host became available
    1496889:20210615:131125.140 Got signal [signal:15(SIGTERM),sender_pid:1,sender_uid:0,reaso n:0]. Exiting ...
    1496889:20210615:131127.150 syncing history data...
    1496889:20210615:131127.150 syncing history data done
    1496889:20210615:131127.150 syncing trend data...
    1496889:20210615:131127.332 syncing trend data done
    1496889:20210615:131127.333 Zabbix Server stopped. Zabbix 3.4.10 (revision 81503).
    (END)
    What can I do to fix it?
  • Markku
    • Sep 2018
    • 1784
    Based on the log someone (systemd? pid=1) stopped the Zabbix server process. Maybe your /var/log/syslog or journalctl provides more information about what else happened at 13:11:25.
    Markku
    • FedericoCoppola97
      • Jun 2021
      Dear Markku
      I upgraded Debian OS and later Zabbix software and now it is working fine again.
      Federico
