Value "2,14" of type "string" is not suitable for value type "Numeric (float)"
  • JSERRAHIMA
    • May 2021
    • 16
    I'm monitoring Oracle DB and aplying Template DB Oracle by ODBC.
    DB is conifigured like
    select * from sys.nls_database_parameters where parameter = 'NLS_NUMERIC_CHARACTERS';
    | NLS_NUMERIC_CHARACTERS | ., |
    Template is not modified but still getting that error :/
    What else can i try? Sql query is returnning values and them are rigth formated so ...
    Regards.
  • Markku
    • Sep 2018
    • 1784
    Can you use a preprosessing rule and replace comma with a dot?
    Markku
    • JSERRAHIMA
      • May 2021
      • 16
      Hi ,
      I am almost but not entirely sure, that Zabbix is not doing lookup into DB settings to decide, how to interpret numbers... with . or , or both. So, try to insert 2.14 instead of 2,14.
      Is there a way to test or forcing to do it?
      I'm trying but, because i'm using an ODBC template, acccesing monitor does not allow me to modify or add any preprocessing.
      Regards.
      • Markku
        • Sep 2018
        • 1784
        Originally posted by JSERRAHIMA
        Hi ,
        Do you mean that you cannot change the items because they are created by the discovery rules? In that case change the item prototype in the discovery rule.
        Markku
        • JSERRAHIMA
          • May 2021
          • 16
          Hi Markku,
          Thank you so much. It works!!!
          Regards.
            • 4996
            I am almost but not entirely sure, that Zabbix is not doing lookup into DB settings to decide, how to interpret numbers... with . or , or both.So, try to insert 2.14 instead of 2,14.
            • JollyJumper
              • Mar 2023
              • 12
              Markku
              hello @Markku,
              where in the template I have to change "," to "." ?
              Click image for larger version  Name:	obraz.png Views:	0 Size:	47.9 KB ID:	461478​
              Click image for larger version  Name:	obraz.png Views:	0 Size:	23.0 KB ID:	461479​
              Click image for larger version  Name:	obraz.png Views:	0 Size:	27.3 KB ID:	461480​
              • guille.rodriguez
                • Jun 2022
                • 120
                Add another step on preprocessing (2nd) , select Javascript and add this code
                return value.replace(',','.');
                Save, execute Discovery again (to force changes on device item) and test
                • JollyJumper
                  • Mar 2023
                  • 12
                  thx !
                  • now it works
                  • JollyJumper
                    • Mar 2023
                    • 12
                    I have another problem:
                    Database discovery : Cannot execute ODBC query: [SQL_ERROR]:[42S22][904][[Oracle][ODBC][Ora]ORA-00904: "CDB":invalid identifier
                    PDB discovery: Cannot execute ODBC query: [SQL_ERROR]:[42S02][942][[Oracle][ODBC][Ora]ORA-00942: table or perspective does not exist
                    • JollyJumper
                      • Mar 2023
                      • 12
                      hello,
                      what can i do when i get this message "empty" or "minus" data?
                      Value "" of type "string" is not suitable for value type "Numeric (unsigned)"​
                      Value "-68693237760" of type "string" is not suitable for value type "Numeric (unsigned)"​
                      • guille.rodriguez
                        • Jun 2022
                        • 120
                        If the output its empty ... you can't do anything.. there's no data... maybe you can set to 0 , but you need to know the real values of all the outputs that you check.
                        if ( value === "" )
                        return 0
                        Change the type of data to Float (to allow negative numbers and decimal numbers)
                        • JollyJumper
                          • Mar 2023
                          • 12
                          if ( value === "" )
                          return 0
                          i have Float data type.
                          why in the Name of the "Tablespace used, bytes" author ot this template use "numeric unsigned"
                          and
                          why in the Name of the "Tablespace used, percent" authot ot this template use "numeric float"
                            • 4996
                            and
                            because you cannot have half a byte or 1.34 byte or negative amount of bytes... you have whole number always... that's what unsigned means.
                            and same goes to percent.. it is usually a floating point number... you can have 15.78%.
                            • JollyJumper
                              • Mar 2023
                              • 12
                              #15
                              • thanks for explaining
