UserParameter script returnig empty string
  • markfree
    • Apr 2019
    • 875
    I'm trying to execute a script using UserParameters but Zabbix server is receiving an empty string.
    Click image for larger version  Name:	empty_string.PNG Views:	0 Size:	3.5 KB ID:	426708
    Zabbix Server 4.4.4 in CentOS 7
    Host Windows 2012
    UserParameter=log_dcsp_urs_p,powershell -ExecutionPolicy bypass -Command (Get-Item E:\DIR\PATH).LastWriteTime.ToString('dd-MM-yyyy HH:mm:ss')
    When I try to execute the custom key using Zabbix_Get, it also receives an empty string.
    $ zabbix_get -s 172.24.168.24 -k log_dcsp_urs_p
    But, when I test the item within the server itself using the zabbix agent, it shows me the expected result.
    C:\zabbix\bin>zabbix_agentd.exe -c C:\zabbix\conf\zabbix_agentd.conf -t log_dcsp_urs_p
    log_dcsp_urs_p [t|17-06-2021 10:34:22]
    There is no error message related to this key in the agent's log neither in the server's log.
    And I can't seem to find the root cause for this behavior.
    Any ideas?
  • markfree
    • Apr 2019
    • 875
    Sorry, I forgot to mention the Server version and host OS information. Edited the post above.
    It seems the issue is in between the host and zabbix server.
    But I still haven't found it yet.
    • markfree
      • Apr 2019
      • 875
      I'm returning to this issue only now. It is still happening occasionally..
      I've captured Zabbix Agent log and it reports an empty string as well.
      9304:20211124:090825.833 Requested [log_dcsp_urs_p]
      9304:20211124:090825.872 EXECUTE_STR() command:'powershell -ExecutionPolicy bypass -Command (Get-Item E:\DIR\PATH).LastWriteTim e.ToString('dd-MM-yyyy HH:mm:ss')' len:0 cmd_result:''
      9304:20211124:090825.873 Sending back []
      I've also tried changing the item's key to "system.run", but the outcome is the same.
      system.run[powershell -ExecutionPolicy bypass -Command "(Get-Item E:\DIR\PATH).LastWriteTim e.ToString('dd-MM-yyyy HH:mm:ss')"]
      • tim.mooney
        • Dec 2012
        • 1436
        How long does this command typically take to run? Is it possible it's exceeding the agent item timeout?
        • markfree
          • Apr 2019
          • 875
          It runs almost instantly. It's very fast.
          • splitek
            • Dec 2018
            • 101
            Originally posted by markfree
            [SIZE=16px][FONT=Arial]I'm returning to this issue only now. It is still happening occasionally..
            "occasionally" - so I think it may be something related to powershell.
            I suggest you to put this command in "ps1" file and run this file from userparameter, like:
            system.run[C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe -ExecutionPolicy Bypass -file C:\path_to_script\some.ps1]
            Also add logging what is returned from command to some log file.
            Maybe this way you will find where is a problem.
            • markfree
              • Apr 2019
              • 875
              It seems like a PS issue but it only occurs with Zabbix server.
              If I execute it directly from cli, it always outputs the correct result.
              Anyhow, I'll follow your suggestion and place that PS command whitin a script.
                • 4996
                Tried to replicate... Same userparameter (just different directory/file).. No issues whatsoever. Getting values with test, with zabbix_get and also by normal polling..
                  • 4996
                  My test was with 4.4.10 and 2012R2...
