Losing data off and on in Zabbix 5.0 LTS
  • nakadoma
    • Nov 2015
    Hi we are having a problem and wanted to see if anybody on the forum had advice for us to see if we were on the right track.
    We are having the problem described in the following link https://serverfault.com/questions/90...inconsistently
    We have the same problem. We lose data sometimes a day at a time across all server.
    As you can see the in the text below we currently have 2 problems pollers are
    Ack Actions Tags
    11:29:47 Average PROBLEM rh_zabbix Zabbix unreachable poller processes more than 75% busy 8h 57m 8s No
    12:31:48 Warning PROBLEM rh_zabbix There are items missing data for more than 60 minutes
    We seem to have a manageable amount of new values processed per second about 350 on average.
    Our database server is not wanting for CPU and it has 24 GB RAM
    The zabbix processor has 16 GB RAM.
    To solve the above and according to the link above, we believe we have to adjust our settings.
    At this time we do not think its the number of database syncers which is the default 4. There did not seem to have any db_syncer issues in the logs.
    We mainly want to target increasing the regular pollers, the unreachable pollers and the amount of history cache because according to our stats suggest that those are the processes that are busy.
    We did not find any connection problems in the log.
    Below are the current configuration. Everything not listed is set to default
    StartPollers=32
    StartIPMIPollers=3
    StartPreprocessors=12
    StartPollersUnreachable=2
    StartTrappers=8
    StartPingers=6
    StartDiscoverers=7
    StartHTTPPollers=2
    CacheSize=1G
    CacheUpdateFrequency=180
    # StartDBSyncers=4
    HistoryCacheSize=32M
    TrendCacheSize=32M
    Timeout=15
    Below are the proposed configuration
    StartPollers=42
    StartIPMIPollers=3
    StartPollersUnreachable=8
    StartTrappers=8
    StartPingers=6
    StartDiscoverers=7
    StartHTTPPollers=2
    CacheSize=1G
    # StartDBSyncers=4
    HistoryCacheSize=128M
    TrendCacheSize=32M
    Timeout=15
  • nakadoma
    • Nov 2015
    I should have been more specific I don't think that applies we are using
    zabbix_server (Zabbix) 5.0.12
    Revision c60195b3f9 24 May 2021, compilation time: May 24 2021 12:36:03
    • nakadoma
      • Nov 2015
      Hi this is still happening and we haven't figured it out yet. As I said Its a higher version than 5.0.1 thanks.
