Please tell me about the reading processing of log items when host is disabled and re-enabled.
We are experiencing an issue where entries for a certain period of time are not being getting by the log item monitoring.
Every day, before stopping the application, We disable the host to disable the monitoring itself, and then re-enable it when restarting the application. I think this may be the cause of the problem.
The item is logrt, and the mode is all (not skip), so I assume that when the host is enabled, the log for the period when it was disabled will be also read back.
Please let me know if this is the case as a specification.
<Environment>
Zabbix server : ZABBIX 4.0.8
Zabbix agent : Zabbix Agent 4.0.7 on windows
Dbms : mysql Ver 8.0.16
<Environment>
