unknown PSK identity
  • Janet Kew
    • Jan 2021
    • 11
    I get this error on zabbix server in /var/log/zabbix_agentd.log
    1281:20210706:171748.842 cannot find requested PSK identity "server-one", available PSK identity "zabbix-server"
    1281:20210706:171748.842 failed to accept an incoming connection: from 127.0.0.1: TLS handshake set result code to 1: file s3_srvr.c line 2768: error:1408B0DF:SSL routines:ssl3_get_client_key_exchangesk identity not found: TLS write fatal alert "unknown PSK identity"
  • Markku
    • Sep 2018
    • 1784
    So your Zabbix agent expects PSK identity "zabbix-server" but your Zabbix server tries to connect to the agent with PSK identity of "server-one". What happens if you correct either side of the configuration and use the same PSK identity value on both sides?
    Markku
    • Janet Kew
      • Jan 2021
      • 11
      I'm trying to implement https://github.com/sleepka/zabbix-kubernetes-monitoring and after importing template to zabbix dashboard and attaching it to kubernetes cluster nodes (each node is on separate server, and zabbix server is on separate server) I get same error in the Dashboard under Availability: ZBX is red and says the same message as in the zabbix_agentd.log
      • Janet Kew
        • Jan 2021
        • 11
        on zabbix dashboard, on the host, under Interfaces I changed the IP address of the agent from 127.0.0.1 to the IP address of the server that hosts this agent and then I get another error:
        Get value from agent failed: cannot connect to [[ip_address]:10050]: [4] Interrupted system call
