Zabbix Agent Installation with powershell
  • wtfhelllord
    • Jul 2021
    Hi
    I wanted to know if this is zabbix problem or not.
    So my script is like this
    ##SCRIPT
    $CheckInstalled = Get-WmiObject -Class Win32_Product | Where-Object {$_.Name -like "zabbix agent*"}
    if( $CheckInstalled.IdentifyingNumber -eq "{Product code}")
    {write-host Right Version}
    Else{
    $CheckInstalled = $null
    $InstallLocation = "C:\Temporary."
    $MSIFile = "zabbix_agent-5.4.2-windows-amd64-openssl.msi"
    $exe = "msiexec.exe"
    $ZabbixServer = "local.com"
    $serveractive = "proxy.com:10051"
    $hostFQDN = ([System.Net.Dns]::GetHostByName(($env:computerName))).HostName
    #$PSKIDENTITY="<PSK IDENTIFY>"
    #$PSKKEY="<PSK KEY>"
    $Arguments = "/i $InstallLocation\$MSIFile HOSTNAME=$hostFQDN SERVER=$ZabbixServer SERVERACTIVE=$serveractive ENABLEPATH=TRUE LOGTYPE=file /qn"
    $AgentVersion = "5.4.2"
    $InstallDestination = ($env:ProgramFiles)+"\Zabbix Agent"
    $ZabbixConfig = "zabbix_agentd.conf"
    #get-wmiobject Win32_Product | Format-Table IdentifyingNumber, Name
    #$CheckInstalled = $null
    #First Install
    If ($null -eq $CheckInstalled){
    Start-Process -FilePath $exe -ArgumentList $Arguments -Wait
    Start-Sleep -s 10
    # Update zabbix_agentd.conf for HOSTMETADATA
    $GetFile = Get-Content -Path "$InstallDestination\$ZabbixConfig"
    #$GetFile -replace '# HostMetadata=', 'HostMetadata=Windows' #| Set-Content -Path "$InstallDestination\$ZabbixConfig"
    #$GetFile -replace '# HostMetadataItem=', 'HostMetadataItem=system.uname' #| Set-Content -Path "$InstallDestination\$ZabbixConfig"
    #$GetFile -replace '# 1 - AllowKey=system.run[*]', 'AllowKey=system.run[*]' | Set-Content -Path "$InstallDestination\$ZabbixConfig"
    $GetFile -replace '# HostMetadata=', 'HostMetadata=Windows' -replace '# HostMetadataItem=' -replace '# LogRemoteCommands=0', 'AllowKey=system.run[*]' | Set-Content -Path "$InstallDestination\$ZabbixConfig"
    sc.exe failure 'zabbix agent' reset= "" actions= restart/1200
    sc.exe config 'zabbix agent' start= auto
    Start-Sleep -s 3
    Stop-Service -Name 'Zabbix Agent'
    #Set-Service -name 'Zabbix Agent' -StartupType Automatic
    Start-Sleep -s 3
    #Get-Service -Name 'Zabbix Agent' | Start-Service
    Start-Service -name 'Zabbix agent'
    Start-Service -name "Zabbix*"
    Start-Sleep -s 5
    if ($null -ne $CheckInstalled -and $CheckInstalled.Version -lt $AgentVersion){
    $version=$CheckInstalled.IdentifyingNumber
    Stop-Service -Name "Zabbix Agent"
    #$uninstall="/x $version​​​ /qn"
    Start-Process msiexec.exe "/x $version /qn /norestart"
    Start-Sleep -s 3
    #$GetFile -replace '# HostMetadata=', 'HostMetadata=Windows' | Set-Content -Path "$InstallDestination\$ZabbixConfig"
    #$GetFile -replace '# HostMetadataItem=' | Set-Content -Path "$InstallDestination\$ZabbixConfig"
    #$GetFile -replace '# LogRemoteCommands=0', 'LogRemoteCommands=AllowKey=system.run[*]' | Set-Content -Path "$InstallDestination\$ZabbixConfig"
    Restart-Service -Name 'Zabbix Agent'
    Get-Service -Name 'Zabbix Agent' | set-service -StartupType Automatic
    Basically it works with 5.0 and older versions but not anymore with the 5.4
    My second problem is that the conf file doesnt add right hostname. etc i have test-test.local.com but unfortunately it write only test-test.
    i would be grateful for any help
