Remote Commands selection missing in zabbix version 5.4.2
  • Sankaralingam
    • Jul 2021
    I unable to find remote commands option in Configuration --> Action --> Operations section in zabbix version 5.4.2. Please guide me how to enable it, Thank you
    Remote command option is available in 5.0 or earlier versions
  • Markku
    • Sep 2018
    • 1790
    Does this help?
    Operation Select the operation:
    Send message - send message to user
    <remote command name> - execute a remote command. Commands are available for execution if previously defined in global scripts with Action operation selected as its scope.
    Markku
    • Sankaralingam
      • Jul 2021
      In the document https://www.zabbix.com/documentation...g_an_operation, we can clearly see drop down menu in operation type.
      In zabbix 5.4.2 version, I couldn't see an option to select operation type as remote command
      • studentfet1
        • Jul 2021
        Я столкнулся с аналогичной проблемой. Есть ли решение по ней?
        Вкладка Operation не доступна для выбора Удаленная команда
        • Markku
          • Sep 2018
          • 1790
          How did you configure your global script? https://www.zabbix.com/documentation..._global_script
          Markku
          • Glencoe
            Zabbix developer
            • Oct 2019
            • 153
            You can only use "Send message" as an operation for Internal actions. You can use other operation types in Trigger actions, Discovery actions etc
            • studentfet1
              • Jul 2021
              Нет, в действиях триггеров я наблюдаю аналогичную проблему
              • studentfet1
                • Jul 2021
                Markku
                Мне не нужен запуск моего скрипта мне необходим пункт Удаленная команда который присутствует в ранних версиях Zabbix по умолчанию
                • Atsushi
                  Atsushi commented
                  That's why you set the remote command you want to execute as one of the global scripts. The location to set has changed. Then, in the action settings, select the one you set.
              • bargavashok
                • Aug 2021
                Sankaralingam
                I was stuck with the same issue. Solved it by the below steps. Have to create a global script first with the scope of action operation. You will then be able to see the dropdown.
                More operations are available for discovery and autoregistration based events (see above).
