Zabbix 5 (LTS) ans Server 2019 ADFS Configuration
  • JMAIV
    • Oct 2016
    • 26
    Hi All,
    We have migrated our Zabbix 3 server to a new Zabbix 5 server. because Zabbix 5 supports SAML, I figured I'd give it a go...
    Yet it seems to be a bit of a challange to me.
    my current config in Zabbix:
    Click image for larger version  Name:	Zabbix2_SAML.png Views:	0 Size:	36.4 KB ID:	428048
    the error message:
    I've tried several configurations. Altering the username attribute to just about anything. but i can't find a way to get it work.
    Any ssuggestions on how to debug this?
    thanks!!
  • JMAIV
    • Oct 2016
    • 26
    anyone with a spare minute or to?
    • dhellstern
      • Aug 2021
      The SAML document returned by ADFS is missing an assertion containing the username (or it may have one, but with a different name). Make sure the ADFS server is adding an assertion containing the username, with a matching name in Zabbix. Then, try to capture a request and extract the SAML assertion, decode it (using something like CyberChef), and see what assertions it contains.
      • emilien.henry
        • Feb 2020
        Hey,
        You should map UPN as exiting claim and Client ID (and the what you want for your active directory attribute) on AD FS.
        Use http://schemas.xmlsoap.org/ws/2005/0...ity/claims/upn as Username attribute in Zabbix.
        • JMAIV
          • Oct 2016
          • 26
          thank you for your suggestions, sorry it's been a while. I will try this and report back.
