Adding performance counters failed
  • zabzab98
    • Jul 2021
    Im having a problem with the Zabbix Agent adding the performance counters on Windows Servers for the CPU utilization.
    We are using Zabbix Version 5.4 and Agent 2 Version 5.4.2.
    When using an older agent like 5.0, the performance counters can be added and are working.
    Heres a short output of the agent log file:
    It says that the performance counters cant be added because it couldnt find the related object on the computer.
    2021/07/13 10:45:58.010691 received passive check request: 'system.cpu.util' from 'xx.xx.xx.xx'
    2021/07/13 10:45:58.010691 [1] processing update request (1 requests)
    2021/07/13 10:45:58.010691 [1] adding new request for key: 'system.cpu.util'
    2021/07/13 10:45:58.010691 [1] created collector task for plugin Cpu with collecting interval 1
    2021/07/13 10:45:58.010691 [1] created direct exporter task for plugin 'Cpu' itemid:0 key 'system.cpu.util'
    2021/07/13 10:45:58.010691 [1] created starter task for plugin Cpu
    2021/07/13 10:45:58.011683 plugin Cpu: executing starter task
    2021/07/13 10:45:58.013684 [Cpu] cannot add performance counter for total CPU utilization: Das angegebene Objekt wurde nicht auf dem Computer gefunden.
    2021/07/13 10:45:58.013684 [Cpu] cpu_groups = 1, cpus_per_group = 2, cpus = 2
    2021/07/13 10:45:58.013684 [Cpu] cannot add performance counter for CPU#0,0 utilization: Das angegebene Objekt wurde nicht auf dem Computer gefunden.
    2021/07/13 10:45:58.013684 [Cpu] cannot add performance counter for CPU#0,1 utilization: Das angegebene Objekt wurde nicht auf dem Computer gefunden.
    If you need further information, please feel free to ask!
  • Hamardaban
    • May 2019
    • 2714
    https://support.zabbix.com/browse/ZBX-19116 ?
    or
    Hello everyone.  I registered just to ask this question, which I could not find after quite a long while consulting Google.  I come to you all in hopes that where Google failed, you will not! I use a program that some of you may be familiar with,…
