Zabbix Server is not running:the information display may not correct
  • S Sathish Reddy
    • Jul 2021
    Hi i installed Zabbix 5.4 recently. I am able open GUI in web browser.
    But when i added nodes unable ping from GUI and able to ping from zabbix server.
    And also in dashboard zabbix server is running showing as no
  • DataplanITPartner
    • Jul 2021
    We're having the exact same issue right now. I would suggest you start off by checking the status of the Zabbix Service using
    sudo systemctl status zabbix-server
    , and then by trying to restart the service using
    sudo systemctl restart zabbix-server
    if it still fails, check the log file using
    tail -n 100 /var/log/zabbix/zabbix_server.log
    Follow the last part of the log where it starts with "Starting Zabbix Server.". If you need further help, look for other posts which show the same errors you can see, or paste the log here if you find no matches. Good luck resolving your issue!
