Hi
When navigating to Monitoring -> hosts -> graphs for a host which has graphs based on a discovery rule, all graphs are showed with the correct name in the graph-header.
However, when you want to select a specific graph, the names are messed up like a macro . For example : {{HOSTNAME}:ifAlias[Vlan508].last(0)} instead the real alias behind the macro.
Is this a bug, of can i fix this within the code ?
regards Nathan
regards Nathan
