Slack webhook cannot get URL ssl connection error
  • Trixikus
    • Jul 2021
    Hello, An error occurs with zabbix_url , what can it be related to and how to fix it? Slack notification failed : Error: cannot get URL: SSL connect error
  • Glencoe
    Zabbix developer
    • Oct 2019
    • 153
    It looks like your Zabbix instance uses libcurl that can not validate slack.com certificate. Check your curl version and make sure it can verify Slack's certificate and CAs.
    • Trixikus
      Trixikus commented
      version 7.61.1
      curl https://slack.com/api/
      curl: (35) OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to slack.com:443
      I think this is really the problem.
  • Trixikus
    • Jul 2021
    Curl version updated, but now curl: (35) OpenSSL SSL_connect: Reset peer connection when connecting to api.slack.com:443
    • Glencoe
      Zabbix developer
      • Oct 2019
      • 153
      Try running curl with -v option, it should give you more hints.
      • Trixikus
        • Jul 2021
        curl -v https://api.slack.com
        * Trying 3.10.95.11:443...
        * Connected to api.slack.com (3.10.95.11) port 443 (#0)
        * ALPN, offering h2
        * ALPN, offering http/1.1
        * successfully set certificate verify locations:
        * CAfile: /etc/pki/tls/certs/ca-bundle.crt
        * CApath: none
        * TLSv1.3 (OUT), TLS handshake, Client hello (1):
        * OpenSSL SSL_connect: Connection reset by peer in connection to api.slack.com:443
        * Closing connection 0
        curl: (35) OpenSSL SSL_connect: Connection reset by peer in connection to api.slack.com:443
        • Glencoe
          Zabbix developer
          • Oct 2019
          • 153
          Not much clue in here.. How about curl --trace log.txt ?
          • somesh_k
            • Feb 2023
            • 12
            Hi ,
            Any solution on above problem.I am facing same issue in the webhook call.
