Graphs Inside Screens Broken
  • scottk
    • Aug 2015
    I am having kind of an odd problem. I have several graphs that work when I go directly to Monitoring -> Graphs. When I go to Monitoring -> Screens however and select a screen that uses the same graphs using the same time interval, sometimes they do work, but often times the graphs show "no data".
    Any advice on what I can start looking at?
  • dirckcopeland
    • Oct 2013
    • 50
    Scott,
    Just curious if when you look at the same graph in the latest data for a host does it show correctly?
    • scottk
      • Aug 2015
      Originally posted by dirckcopeland
      Scott,
      Yes. One thing that I should probably note is that I am graphing a trapper item that is only collected once a day. If I go directly to the graph I will see the data as long as I set the zoom far enough out where the data point will show up.
      If I go to the screen and select the same zoom, often I will get "no data". Oddly enough it seems to be working this morning, so I guess I am looking for explanations as to what is causing this inconsistency.
