local admin login not working after ldap configuration.
  • zSteve
    • Jul 2021
    Hi Guys,
    I've tried to find the answer to my problem via the search but I cant seem to see it anywhere so here I am - hopefully its a simple question to answer!
    My platform = Zabbix 5.0.14. © 2001–2021, Zabbix SIA
    Issue is the local Admin login is not working once I configured the ldap authentication.
    Cheers,
    Steve
  • LordGraves
    • Jan 2022
    • 17
    Just ran into this myself. Did you ever find a solution for this?
    • rthonpm
      • Jan 2016
      • 44
      By local admin, I'm guessing you mean the default Zabbix account? Create a group for it and any other local accounts with Internal set as the Frontend Authentication method and the appropriate roles for the users. Once the group is created you can confirm from Administration > User groups that the correct method is being used for all of your user groups.
      Sent from my BBE100-5 using Tapatalk
      • LordGraves
        • Jan 2022
        • 17
        Thats exactly what I ended up doing last Friday. Thank you!
