Hello everyone.
Possibly someone already faced such an issue like I had, because I didn't found any information in the log and www have to ask here.
What we have :
Separate ZBX server with 5.0.9 version
MariaDB 10.5.9 in RDS
what had happened:
1)Trappers raised up to 100%, with zabbix action logging for trappers was increased
2) about 10 minutes there such type of message
3) Zabbix decided to restart itself
4) After the start some log exist and everything stopped
There is no data in the log then. We had to restart it manually.
Also, I found an agent failed with the error "Get value from agent failed: ZBX_TCP_READ() timed out"
Any ideas what kind of problem ut was
What we have :
what had happened:
3638:20210728:010056.516 log level has been increased to 4 (debug)
3621:20210728:010056.516 query [txnlev:0] [update ids set nextid=nextid+1 where table_name='auditlog' and field_name='auditid'] 3637:20210728:010056.518 query [txnlev:0] [select nextid from ids where table_name='auditlog' and field_name='auditid'] 3637:20210728:010056.520 query [txnlev:0] [select nextid from ids where table_name='auditlog' and field_name='auditid'] 3637:20210728:010056.521 query without transaction detected
1687:20210728:011205.202 Got signal [signal:15(SIGTERM),sender_pid:9564,sender_uid:0,re ason:0]. Exiting ... 1687:20210728:011209.325 Zabbix Server stopped. Zabbix 5.0.9 (revision 4d07aaafe2).
#freeze start 9874:20210728:011255.177 slow query: 5.576526 sec, "select clock,ns,value from history where itemid=64471699 and clock>1627391568" 9855:20210728:011255.178 slow query: 4.883012 sec, "select clock,ns,value from history where itemid=42307399 and clock>1627391569" 9838:20210728:011255.178 slow query: 5.601367 sec, "select clock,ns,value from history where itemid=57436399 and clock>1627391568" 9921:20210728:011255.178 slow query: 5.585693 sec, "select clock,ns,value from history where itemid=64331599 and clock>1627391568" 9870:20210728:011255.178 slow query: 5.595507 sec, "select clock,ns,value from history where itemid=60503299 and clock>1627391568" 9842:20210728:011255.179 slow query: 5.577535 sec, "select clock,ns,value from history where itemid=61348699 and clock>1627391568" 9926:20210728:011255.184 slow query: 4.619202 sec, "select clock,ns,value from history where itemid=13474099 and clock>1627391569" 9889:20210728:011255.196 slow query: 5.139961 sec, "select clock,ns,value from history where itemid=53557099 and clock>1627391569"
