Log to file in a docker container
  • alga
    • Aug 2021
    Hi all,
    my Zabbix environment is completely based on docker container, as database I use mariadb also in a docker container.
    The docker-entrypoint.sh from the server has no variable for log method, I can log only to the console:
    update_zbx_config() {
    echo "** Preparing Zabbix server configuration file"
    ZBX_CONFIG=$ZABBIX_ETC_DIR/zabbix_server.conf
    update_config_var $ZBX_CONFIG "ListenIP" "${ZBX_LISTENIP}"
    update_config_var $ZBX_CONFIG "ListenPort" "${ZBX_LISTENPORT}"
    update_config_var $ZBX_CONFIG "SourceIP" "${ZBX_SOURCEIP}"
    update_config_var $ZBX_CONFIG "LogType" "console"
    update_config_var $ZBX_CONFIG "LogFile"
    update_config_var $ZBX_CONFIG "LogFileSize"
    update_config_var $ZBX_CONFIG "PidFile"
    Can you please set for LogType, LogFile and LogSize also variables?
    Or rather give the possibility map the zabbix_server.conf from the host into container?
    Regards
    Wladimir
