Delete old hosts
  • ZaToWarlock
    • Jul 2021
    Delete old hosts
    Greetings. Who used the automatic deletion of hosts? Computers are periodically disconnected in the network (broken, updated to a new one, etc.), respectively, the old IP must be removed from monitoring, since they disappear in DHCP via TTL, which means they are not needed in Zabbix. Configured a discovery action:
    In theory, if a host is offline for 10 days, then it should send me a notification and delete this host. For verification, I also added a disable host. A message is sent to me, the hosts are deactivated, but the operation "Remove host" does not work. Strange, not working operation.
  • Pekle
    • Feb 2023
    ZaToWarlock Did you ever figure this one out? I am attempting a similar solution in my environment.
