Hi guys,
I'm using Zabbix 5.4.3 and my database is Mariadb 10.3.31
When I adding a IIS template my vm Zabbix is crashing and when I unlink the template it's keep going work.
Is ıt bug or am I doing wrong anything?
This log is zabbix-server
34514:20210814:221027.271 Starting Zabbix Server. Zabbix 5.4.3 (revision 68dc2b05cb). 34514:20210814:221027.271 ****** Enabled features ****** 34514:20210814:221027.271 SNMP monitoring: YES 34514:20210814:221027.271 IPMI monitoring: YES 34514:20210814:221027.271 Web monitoring: YES 34514:20210814:221027.271 VMware monitoring: YES 34514:20210814:221027.271 SMTP authentication: YES 34514:20210814:221027.271 ODBC: YES 34514:20210814:221027.271 SSH support: YES 34514:20210814:221027.271 IPv6 support: YES 34514:20210814:221027.271 TLS support: YES 34514:20210814:221027.271 ****************************** 34514:20210814:221027.271 using configuration file: /etc/zabbix/zabbix_server.conf 34514:20210814:221027.280 current database version (mandatory/optional): 05040000/05040000 34514:20210814:221027.280 required mandatory version: 05040000 34514:20210814:221027.292 server #0 started [main process] 34515:20210814:221027.293 server #1 started [configuration syncer #1] 34515:20210814:221027.411 __mem_malloc: skipped 0 asked 24 skip_min 18446744073709551615 skip_max 0 34515:20210814:221027.411 [file:dbconfig.c,line:102] __zbx_mem_realloc(): out of memory (requested 16 bytes) 34515:20210814:221027.411 [file:dbconfig.c,line:102] __zbx_mem_realloc(): please increase CacheSize configuration parameter 34515:20210814:221027.411 === memory statistics for configuration cache === 34515:20210814:221027.411 min chunk size: 18446744073709551615 bytes 34515:20210814:221027.411 max chunk size: 0 bytes 34515:20210814:221027.411 memory of total size 7263192 bytes fragmented into 70316 chunks 34515:20210814:221027.411 of those, 0 bytes are in 0 free chunks 34515:20210814:221027.411 of those, 7263192 bytes are in 70316 used chunks 34515:20210814:221027.411 of those, 1125040 bytes are used by allocation overhead 34515:20210814:221027.411 ================================ 34515:20210814:221027.411 === Backtrace: === 34515:20210814:221027.412 11: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_backtrace+0x52) [0x560e637ff7d2] 34515:20210814:221027.412 10: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](__zbx_mem_realloc+0x164) [0x560e637f9d89] 34515:20210814:221027.412 9: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x1b7e8f) [0x560e6377be8f] 34515:20210814:221027.412 8: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x1c6b48) [0x560e6378ab48] 34515:20210814:221027.412 7: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](DCsync_configuration+0x14b8) [0x560e6378c2f3] 34515:20210814:221027.412 6: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](dbconfig_thread+0x126) [0x560e6362f07b] 34515:20210814:221027.412 5: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_thread_start+0x3b) [0x560e63810d17] 34515:20210814:221027.412 4: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](MAIN_ZABBIX_ENTRY+0xb59) [0x560e6361b7ab] 34515:20210814:221027.412 3: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](daemon_start+0x303) [0x560e637ff314] 34515:20210814:221027.412 2: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](main+0x309) [0x560e6361ab34] 34515:20210814:221027.412 1: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3) [0x7ffb7768f0b3] 34515:20210814:221027.412 0: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](_start+0x2e) [0x560e6361994e] 34514:20210814:221027.415 One child process died (PID:34515,exitcode/signal:1). Exiting ... 34514:20210814:221027.417 syncing trend data... 34514:20210814:221027.417 syncing trend data done 34514:20210814:221027.417 Zabbix Server stopped. Zabbix 5.4.3 (revision 68dc2b05cb).
