Tomcat Monitoring without jmxremote
  • dirtydriver
    • Feb 2013
    • 26
    Dear All!
    I started to work in new company and one of my job is to solve the tomcat instance monitoring , but the problem is the jmxremote option is disabled because it is security issue , so my question is can I monitor the tomcat instance through the zabbix-agent ?
  • Colttt
    • Mar 2009
    • 878
    ehm you can make it secure by using password and SSL ..
    Java Management Extensions (JMX) technology, JMX, enabling with password authentication and SSL
    otherwise it is not possible to monitor tomcat like jmx. you can only check if the server is running and how many cpu/ram it need etc..
    Debian-User
    Sorry for my bad english
    • dirtydriver
      • Feb 2013
      • 26
      I know the password and ssl is secure , but my colleague is littlebit complicated and he think different like me .
