1.0 php error
  • anothergene
    • Feb 2005
    1.0 php error
    Hi all.
    I'm having a problem getting zabbix 1.0 up and running propperly. I've done the install and it's being served up ok, but when I connect to it for the very first time I get the normal log in screen and I enter the default id and password. The next screen I get has this at the top:
    Warning: Cannot modify header information - headers already sent by (output started at /usr/local/apache_1.3.33+php-4.3.10/htdocs/zabbix/include/db.inc.php:11) in /usr/local/apache_1.3.33+php-4.3.10/htdocs/zabbix/index.php on line 89
    Warning: Cannot modify header information - headers already sent by (output started at /usr/local/apache_1.3.33+php-4.3.10/htdocs/zabbix/include/db.inc.php:11) in /usr/local/apache_1.3.33+php-4.3.10/htdocs/zabbix/include/config.inc.php on line 1085
    then when I click on any of the options I get bumped back to being guest.
    I saw some one else had this error with 1.1 and they solved it by putting in a missing semi-colon in the include/db.inc.php file. I've looked through it and I can't find any missing semi-colons.
    I'm using Firefox 1.0 as my browser, would that make any difference?
    Any one have any ideas?
  • riegersteve
    • Oct 2004
    • 68
    check your permissions, all files should be owned by the web user
    • rickardp
      • Dec 2004
      • 27
      Hi!
      This error is a result of a SQL statement that has gone wrong.
      I had that problem when a upgrade script was executed but produced errors which caused an inconsistant table structure in the database.
      See V1.0Beta10 Upgrade to V1.1alfa5 for more info
