We want to trial Zabbix but so far, it has been impossible.
We tried with the ISO first but after booting up it was stuck
"Been trying for 2 days to get an install to work, keep getting the centos stream 8-stream started then get Service org.fedoraproject.anaconda.modules.storage has failed to start: Failed to activate service 'org.fedoraproject.anaconda.modules.storage': timed out ( service_start_timeout=6000000ms)"
After we tried with the OFV.... but it was not build for VMware but for virtual box .... so we had to modify the ovf file to fix all that was incompatible... and then we also got stuck at many errors post boot.
Didn't work
So we then went with the Vmware .vmx but it wasn't compatible with Vcenters but for VmWare workstation so we needed to convert it fist and then this one also didn't work and now my techs are trying to fix the postgress errors in that "appliance).
We then decided to abandon the "pre-package easy appliance route" and we also build a CentOS from scrach and tried installing it manually on it ... my techs are trying to fix issues like
connection refused - database error
1174:20210819:141854.648 [Z3001] connection to database 'zabbix' failed: [2002] Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (111)
1174:20210819:141854.649 database is down: reconnecting in 10 seconds
So how can we make it work easily and fast: kind of tired trying to trial this software.
We are using vmware Vcenter 5.5.
Didn't work
