the table "dbversion" was not found.
  • gvannauw
    • Aug 2021
    Hello everyone
    I was installing Zabbix on one of my Raspberry PI4 computers and ran into above problem when starting to configure the Zabbix environment. I followed the installation instructions to the letter, but at the point where I need to run the command "zcat /usr/share/doc/zabbix-server-mysql*/create.sql.gz | mysql -uzabbix -p zabbix" I receive the message that the repository cannot be found, hence the table entry is not created.
    I have looked through various messages and suggestions but none of them help.
    the os-release for the OS is version 10 (buster)
    Can someone please point me into the right direction sothat I can get Zabbix configured/installed correctly??
    Thanks a million
    Best rgds
    Gino
  • Atsushi
    • Aug 2013
    • 2028
    What version of Zabbix are you trying to use? If you have Zabbix 5.4, please note that the packages and filenames used have changed slightly. Specifically, did you install the package zabbix-sql-scripts? Then use /usr/share/doc/zabbix-sql-scripts/mysql/create.sql.gz to create the initial table and data.
    Please check the procedure on the download page again.
    Zabbix is being downloaded over 4 000 000 times every year for a reason. Download and install Zabbix for free and try it yourself!
    • gvannauw
      • Aug 2021
      hello
      thank you for the information. I was unaware that I could download different versions. It seems I have installed the Zabbix version 5.4.3
      For as far as the packages installed are concerned, I followed the installation instructions.
      I will recheck the procedure
      Thank you very much for your assistance..
      B regards
      • gvannauw
        • Aug 2021
        I would like to restart from scratch .. rather then burning the raspberry OS image again on the SD card, I'd like to remove the entire installation of Zabbix.. are there any instructions available on how to perform this, i.e. complete wipe out of the installed Zabbix software so no traces are left over ??
        • um3n
          • Aug 2021
          • 48
          Hey Gvannauw,
          did you installed via apt? Then you should get it done via
          apt purge <zabbix packages>
          should do the trick.
          This will deinstall the packages you have installed and remove the configfiles as well.
          Maybe run
          apt autoremove && apt autoclean
          after the
          apt purge
          command ;-)
          Good luck!
          - um3n
