Group By Delay Query
  • arovah
    • Nov 2020
    • 43
    Dear Colleagues,
    I have one of query from https://www.youtube.com/watch?v=BSzjrlotRA4&t=1259s to checking Zabbix Proxy Performance Issue , currently i have issue about delay graph of zabbix monitoring.
    Probably from you able to explain this function of query below :
    select count(*), delay from items where flags = 1 group by delay order by count(*) desc;
    What's mean flags = 1 ?
    Really appreciate for your any comment and reply :-)
    Thank You.
  • Glencoe
    Zabbix developer
    • Oct 2019
    • 153
    Hi, where flags = 1 means you're querying discovery rules.
    • arovah
      • Nov 2020
      • 43
      hi Glencoe.
      Thank you for your reply, what's impact if i set interval duration longer before, example existing 1 hour then i setup 2 hour in the discovery rules ?
      If i have total hosts and item like below, how many interval duration can i set in discover rules ?
      Number of hosts (enabled/disabled/templates) 17736 16903 / 706 / 127
      Number of items (enabled/disabled/not supported) 1432344 1348313 / 42306 / 41725
      Number of triggers (enabled/disabled [problem/ok]) 715747 693939 / 21808 [30106 / 663833]
      Thank you
      • arovah
        • Nov 2020
        • 43
        hi cyber
        Thank you for your reply, if i run the query result on below :
        zabbix=# select count(*), delay from items where flags = 1 group by delay order by count (*) desc;
        count | delay
        13000 | 3600
        2817 | 1h
        3 | 2h
        2 | 6h
        1 | 60m
        1 | 1m
        (6 rows)
        Wheter changes delay or duration discovery rules , for example : 2817 | 1h -> 1h changed to be 6h it can fixed the delay graph ?
        What's impact after change the host duration discovery rules?
        Thank you
        • arovah
          • Nov 2020
          • 43
          ok thank you Cyber
            • 4996
            Impact is, that your discoveries are running with longer interval, of course lowering the impact to whole system. But discovery intervals really depend on how often your infra changes and how much is it ok for you to wait... Sometimes it might be absolutely ok to run discovery once a week, sometimes once a day... sometimes you may need 1h interval or even smaller delay...So it is up to you, do you want to discover new things in 1h or in one week...
            • arovah
              • Nov 2020
              • 43
              Thank you cyber , it's very clear :-)
