Zabbix Agent installed on VCSA 6.0?
  • vcsa
    • Sep 2015
    • 10
    I've posted this question on VMware communities as well but I figured I'd ask Zabbix folks directly as well:
    How do I get Zabbix Agent working on VCSA 6.0? (VMware vCenter Server Appliance 6.0)
    It's SLES (Linux) with an apparently proprietary firewall system.
    I'm trying to get the Zabbix Agent installed on the server in order to monitor the baseline foodgroups of the server (CPU, RAM, disk) as well as some basic services (postgre and VPXD).
    Is the Zabbix Agent the best way to do this? Or is there a better way?
  • vcsa
    • Sep 2015
    • 10
    I just wanted to say that a colleague discovered that you can add a firewall exception directly on VCSA 6.0 using the iptables command.
    • reinard
      • Jan 2017
      What worked for me
      This is what i did to install the agent:
      zypper addrepo http://download.opensuse.org/repositories/server:monitoring/SLE_11_SP3/server:monitoring.repo
      zypper refresh
      zypper install zabbix-agent
      This didn't properly setup the log and pid dirs for me, so
      mkdir /var/run/zabbix
      chown zabbix:zabbix /var/run/zabbix/ /var/log/zabbix/
      Then edit /etc/zabbix/zabbix-agentd.conf as needed. It also doesn't properly setup zabbix-agent as a service, so I manually start it:
      /etc/init.d/zabbix-agentd start
      and add the above line to /etc/init.d/after.local as well
      Regarding the firewall this rule opens the port (I could not figure out a way to adjust the port filter via the web interface):
      iptables -A port_filter -p tcp -m tcp --dport 10050 -j ACCEPT
      you'll have to devise some way of saving/restoring this on boot
      for me i did
      iptables-save > /etc/iptables.rules
      and then add
      iptables-restore -c < /etc/iptables.rules
      into /etc/init.d/after.local
      • Sean35
        • Jan 2015
        • 19
        reinard - Thanks for taking the time to post this, hugely helpful.
        • ErikS
          • Feb 2017
          Worked for me too. Thanks reinard!
          • bbrendon
            • Sep 2005
            • 873
            A slightly different way to the above which was very solid. Thanks!
            # Add this to /etc/init.d/after.local (x.x.x.x is the zabbix server)
            /usr/sbin/iptables -I INPUT -s x.x.x.x -j ACCEPT
            # Setup the service to start on boot.
            insserv zabbix-agentd
            I tried to figure out a more graceful way to modify the firewall rules and couldn't. Not a big fan of messing with restore/save myself.
            Unofficial Zabbix Expert
            Blog, Corporate Site
            • troffasky
              • Jul 2008
              • 640
              Would make more sense to use active agent items if allowing connections in to the VCSA is a hassle.
