mysql.db.size template problems
  • grandor
    • Feb 2021
    I have problems with the mysql template since 01/09/21.
    I can still see dates until 08/30/21.
    I was on vacation and didn't change anything - only updates were installed. apt update / upgrade
    So think that the last version 5.4.4 caused the problem.
    Not supported Items for - Databases discovery:
    MySQL: Size of database mysql
    MySQL: Size of database performance_schema
    MySQL: Size of database sys
    MySQL: Size of database zabbix
    Error:
    Invalid parameters: "TLSConnect" cannot be passed as a key parameter.
  • Atsushi
    • Aug 2013
    • 2028
    It seems that it will be fixed in the next version.
    ZBX-19912 : After upgrading to Zabbix 5.0.15, item "mysql.db.size" is not available.
    • grandor
      • Feb 2021
      Today I updated Zabbix server + agent2 to version 5.4.5.
      Problem still exists.
      Error:
      Template DB MySQL by Zabbix agent 2
      - MySQL: Size of database mysql
      - MySQL: Size of database performance_schema
      - MySQL: Size of database sys
      - MySQL: Size of database zabbix
