Zabbix 5 slack webhooks not showing resolved
  • Jason
    • Nov 2007
    • 431
    I've set up slack webhooks and can receive the problems in slack. I foundhttps://www.zabbix.com/forum/zabbix-...799#post422799 which mentions updating the getPermalink function.
    When the problem is resolved then the event isn't being updated and in zabbix it's saying Slack notification failed : channel_not_found.
    The channel is there though as it's posted to it in the first place. Edited to add contents of script
    var SEVERITY_COLORS = [
    '#97AAB3', '#7499FF', '#FFC859',
    '#FFA059', '#E97659', '#E45959'
    var RESOLVE_COLOR = '#009900';
    var SLACK_MODE_HANDLERS = {
    alarm: handlerAlarm,
    event: handlerEvent
    if (!String.prototype.format) {
    String.prototype.format = function() {
    var args = arguments;
    return this.replace(/{(\d+)}/g, function(match, number) {
    return number in args
    ? args[number]
    : match
    function isEventProblem(params) {
    return params.event_value == 1
    && params.event_update_status == 0
    function isEventUpdate(params) {
    && params.event_update_status == 1
    function isEventResolve(params) {
    return params.event_value == 0;
    function getPermalink(channelId, messageTimestamp) {
    var req = new CurlHttpRequest();
    req.AddHeader('Content-Type: application/x-www-form-urlencoded; charset=utf-8');
    req.AddHeader('Authorization: Bearer ' + params.bot_token);
    var resp = JSON.parse(
    req.Post(Slack.getPermalink + '?channel={0}&message_ts={1}'.format(
    channelId,
    messageTimestamp
    ), 'token='+params.bot_token)
    if (req.Status != 200 && !resp.ok) {
    throw resp.error;
    return resp.permalink;
    function createProblemURL(zabbix_url, triggerid, eventid, event_source) {
    var problem_url = '';
    if (event_source === '0') {
    problem_url = '{0}/tr_events.php?triggerid={1}&eventid={2}'
    .format(
    zabbix_url,
    triggerid,
    eventid
    else {
    problem_url = zabbix_url;
    return problem_url;
    function getTagValue(event_tags, key) {
    var pattern = new RegExp('(' + key + ':.+)');
    var tag_value = event_tags
    .split(',')
    .filter(function (v) {
    return v.match(pattern);
    .map(function (v) {
    return v.split(':')[1];
    })[0]
    || 0;
    return tag_value;
    function handlerAlarm(params) {
    var fields = {
    channel: params.channel,
    as_user: params.slack_as_user,
    if (isEventProblem(params)) {
    fields.attachments = [
    createMessage(
    SEVERITY_COLORS[params.event_nseverity] || 0,
    params.event_date,
    params.event_time,
    createProblemURL(params.zabbix_url, params.trigger_id, params.event_id, params.event_source)
    var resp = JSON.parse(req.Post(Slack.postMessage, JSON.stringify(fields)));
    throw resp.error;
    result.tags.__message_ts = resp.ts;
    result.tags.__channel_id = resp.channel;
    result.tags.__channel_name = params.channel;
    result.tags.__message_link = getPermalink(resp.channel, resp.ts);
    else if (isEventUpdate(params)) {
    fields.thread_ts = getTagValue(params.event_tags, 'message_ts');
    createMessage(
    params.event_update_date,
    params.event_update_time,
    createProblemURL(params.zabbix_url, params.trigger_id, params.event_id, params.event_source),
    true
    throw resp.error;
    else if (isEventResolve(params)) {
    fields.channel = getTagValue(params.event_tags, 'channel_id');
    fields.text = '';
    fields.ts = getTagValue(params.event_tags, 'message_ts');
    createMessage(
    RESOLVE_COLOR,
    params.event_date,
    params.event_time,
    resp = JSON.parse(req.Post(Slack.chatUpdate, JSON.stringify(fields)));
    throw resp.error;
    function handlerEvent(params) {
    var fields = {
    createMessage(
    params.event_date,
    params.event_time,
    throw resp.error;
    createMessage(
    false
    throw resp.error;
    createMessage(
    RESOLVE_COLOR,
    params.event_recovery_date,
    params.event_recovery_time,
    throw resp.error;
    function createMessage(
    event_severity_color,
    event_date,
    event_time,
    problem_url,
    isShort,
    messageText
    var message = {
    fallback: params.alert_subject,
    title: params.alert_subject,
    color: event_severity_color,
    title_link: problem_url,
    pretext: messageText || '',
    fields: [
    title: 'Host',
    value: '{0} [{1}]'.format(params.host_name, params.host_conn),
    short: true
    title: 'Event time',
    value: '{0} {1}'.format(event_date, event_time),
    short: true
    if (params.event_source === '0') {
    message.fields.push(
    title: 'Severity',
    value: params.event_severity,
    short: true
    title: 'Opdata',
    value: params.event_opdata,
    short: true
    if (!isShort && params.event_source === '0') {
    message['actions'] = [
    type: 'button',
    text: 'Open in Zabbix',
    url: problem_url
    title: 'Event tags',
    value: params.event_tags.replace(/__.+?:(.+?,|.+)/g, '') || 'None',
    short: true
    title: 'Trigger description',
    value: params.trigger_description,
    short: true
    if (params.event_source !== '0' || params.event_update_status === '1') {
    title: 'Details',
    value: params.alert_message,
    short: false
    return message;
    function validateParams(params) {
    if (typeof params.bot_token !== 'string' || params.bot_token.trim() === '') {
    throw 'Field "bot_token" cannot be empty';
    if (typeof params.channel !== 'string' || params.channel.trim() === '') {
    throw 'Field "channel" cannot be empty';
    if (isNaN(params.event_id)) {
    throw 'Field "event_id" is not a number';
    if ([0, 1, 2, 3].indexOf(parseInt(params.event_source)) === -1) {
    throw 'Incorrect "event_source" parameter given: "' + params.event_source + '".\nMust be 0-3.';
    if (params.event_source !== '0') {
    params.event_nseverity = '0';
    params.event_severity = 'Not classified';
    params.event_update_status = '0';
    params.slack_mode = 'event';
    if (params.event_source === '1' || params.event_source === '2') {
    params.event_value = '1';
    if (params.event_source === '1') {
    params.host_name = params.discovery_host_dns;
    params.host_ip = params.discovery_host_ip;
    if (!~[0, 1, 2, 3, 4, 5].indexOf(parseInt(params.event_nseverity))) {
    throw 'Incorrect "event_nseverity" parameter given: ' + params.event_nseverity + '\nMust be 0-5.';
    if (typeof params.event_severity !== 'string' || params.event_severity.trim() === '') {
    throw 'Field "event_severity" cannot be empty';
    if (params.event_update_status !== '0' && params.event_update_status !== '1') {
    throw 'Incorrect "event_update_status" parameter given: ' + params.event_update_status + '\nMust be 0 or 1.';
    if (params.event_value !== '0' && params.event_value !== '1') {
    throw 'Incorrect "event_value" parameter given: ' + params.event_value + '\nMust be 0 or 1.';
    if (typeof params.host_conn !== 'string' || params.host_conn.trim() === '') {
    throw 'Field "host_conn" cannot be empty';
    if (typeof params.host_name !== 'string' || params.host_name.trim() === '') {
    throw 'Field "host_name" cannot be empty';
    if (!~['true', 'false'].indexOf(params.slack_as_user.toLowerCase())) {
    throw 'Incorrect "slack_as_user" parameter given: ' + params.slack_as_user + '\nMust be "true" or "false".';
    if (!~['alarm', 'event'].indexOf(params.slack_mode)) {
    throw 'Incorrect "slack_mode" parameter given: ' + params.slack_mode + '\nMust be "alarm" or "event".';
    if (isNaN(params.trigger_id) && params.event_source === '0') {
    throw 'field "trigger_id" is not a number';
    if (typeof params.zabbix_url !== 'string' || params.zabbix_url.trim() === '') {
    throw 'Field "zabbix_url" cannot be empty';
    if (!/^(http|https):\/\/.+/.test(params.zabbix_url)) {
    throw 'Field "zabbix_url" must contain a schema';
    try {
    var params = JSON.parse(value);
    validateParams(params);
    var req = new CurlHttpRequest(),
    result = {tags: {}};
    if (typeof params.HTTPProxy === 'string' && params.HTTPProxy.trim() !== '') {
    req.SetProxy(params.HTTPProxy);
    req.AddHeader('Content-Type: application/json; charset=utf-8');
    var slack_endpoint = 'https://slack.com/api/';
    var Slack = {
    postMessage: slack_endpoint + 'chat.postMessage',
    getPermalink: slack_endpoint + 'chat.getPermalink',
    chatUpdate: slack_endpoint + 'chat.update'
    params.slack_mode = params.slack_mode.toLowerCase();
    params.slack_mode = params.slack_mode in SLACK_MODE_HANDLERS
    ? params.slack_mode
    : 'alarm';
    SLACK_MODE_HANDLERS[params.slack_mode](params);
    return JSON.stringify(result);
    else {
    return 'OK';
    catch (error) {
    Zabbix.Log(4, '[ Slack Webhook ] Slack notification failed : ' + error);
    throw 'Slack notification failed : ' + error;
