Hi community,
I have this situation: I'm monitoring log files using item type log, and it have been running very well. Some of this log files are fed just once or twice a week. I have set these monitoring items with an interval of 60 seconds, in case that the log files could be fed at unexpected time.
But when someone wants to check the latest data of the monitored log files, that data is not shown unless filter link is clicked and "show items without data" box is checked. Doing this, the item history for those items can be seen, and it can be seen properly and accurately, but the last check column only shows a -.
What I want is to show all the items in latest data without have to check the "show items without data" box, and I can guess that this behavior could be produced by the current interval. Futhermore, I don“t want that the "last check" column for this log files in latest data, log files fed a couple of times a week as I told before, display a -. I want this column showing the last time that the searched string apears.
If my desiree is not reachable using the item type log, how else could I monitor this log files?. Perhaps an obvious answer could be increase the interval, but, what about if the logs are fed at an unexpected time?. Also the item interval has an upper limit of 86400 (24 hours).
Another solution that I could guess is to make a script in the monitored server and schedule it as a zabbix_sender object, but if I have not to add new stuff to the server, it would be better.
Thanks a lot for taking the time to read my post, all the sugestions will be appreciated, and please apologize my english.
Have a nice day!
Luis Morales
Have a nice day!
Luis Morales
