action configuration - cond 1 AND cond2 : Telegram message very late
  • Sambaderiopassiolinis
    • Sep 2021
    • 11
    Hi, I'm newby of Zabbix. I installed 5.4.
    1) I config Telegram messages: tested and working.
    2) I made hosts groups, with SNMP:
    AllCiscoSwitch: all cisco switch on the network.
    Cisco6500: only model 6500 (it is basically a subset of AllCiscoSwitch)
    3) I associated the template "Cisco IOS SNMP" to this switches.
    4) I change the name at the trigger "Unavailable by ICMP ping" to "Ping K.O." (template: ICMP Ping)
    5) I am running this test (example):
    I want to check with template "ICMP Ping" only the group "Cisco6500".
    If I configure the action with only this condition:
    trigger = ICMP Ping K.O.
    all works fine (after about 3 minutes I have the Telegram message on my smartphone) but in this manner I'm testing all hosts on the Zabbix that have associated this trigger, right?
    If I configure the action as I would like, with 2 condition:
    Host Group = Cisco6500
    AND
    I initially thought it didn't work. In reality the message arrived but after a very long time (I was already in the car, I was returning home, disconsolate ).
    Any suggestions?
    Paul.
    • Sep 2021
    • 11
    I have a switch on my table, in hosts group Cisco6500 (not a 6500!!!). If I unplug the cable at 11:49 am, the Telegram message come on my phone at 12:08 (19 min!!!). When I re-plug the cable the message of problem solved come after only 1 minute. I will do other tests
