I have installed Zabbix and adding few nodes that generate large amount of traffic.
When I try to login I get "database error: connection refused" error on the login page.
I have logged into zabbix VM and can see mysql is out of space and the harddrive went full.
Then I restarted the system. Nothing happened, just a blinking cursor after the screen went black.
Then turned off the power and added 4 extra GB RAM and changed the harddrive space from 50 to 100 GB.
And each time the harddrive went full.
I went through many forums and I followed every recommendation but none of them could solve my issue.
Thanks for any help!
