no graph when click on screen
  • cadbury
    • Apr 2005
    • 77
    Hi all,
    I set up a screen with several graphs, works all right
    but when i click on a graph, it doesnt display the graph,
    i have to choose the host and the graph again to display it.
    BUT this only happen the first time!?
    after i chose the host and graph, when i go back to the screen,
    and click again on the same graph, it is displayed perfectly.
    kinda weird and a bit annoying
    I use zabbix 1.1.2 on apache2 php5
    you have the same behavior, or you see where it come from?
  • cybaspace
    • Jul 2005
    • 43
    Roger that. We have exactly the same problem.
    When you want to 'zoom' in on a graph in a screen, you don't get anything.
    When you select the graph manually it works fine.
    • cdouglas97
      • Aug 2006
      same here. It appears that the hostid values are now required to display a graph detail and they are not included in the link on the screen page.
      Here is a quick fix:
      include/screens.inc.php
      add groupid=0&hostid=0&
      Line 216:
      $action ="charts.php?groupid=0&hostid=0&graphid=$resourcei d".url_param("period").url_param("inc").url_param( "dec");
      • cybaspace
        • Jul 2005
        • 43
        Thanks! works like a charm ;-)
        • cadbury
          • Apr 2005
          • 77
          yep, works good
          thanks!
