Zabbix server not start after reboot
  • koko06
    • Sep 2021
    Hi!
    I have a Zabbix server on my Raspberry Pi, I rebooted the Raspberry, but the Zabbix server just not start. I deleted fping before. but I installed it again.
    root@raspberrypi:~# systemctl status zabbix-server
    ● zabbix-server.service - LSB: Start zabbix-server daemon
    Loaded: loaded (/etc/init.d/zabbix-server; generated)
    Active: active (exited) since Sun 2021-09-26 17:05:15 CEST; 2min 55s ago
    Docs: man:systemd-sysv-generator(8)
    Process: 1475 ExecStart=/etc/init.d/zabbix-server start (code=exited, status=0/SUCCESS)
    szept 26 17:05:15 raspberrypi systemd[1]: Starting LSB: Start zabbix-server daemon...
    szept 26 17:05:15 raspberrypi systemd[1]: Started LSB: Start zabbix-server daemon.
    What can be the problem?
    Thank you!
    Attached my log file.
  • tim.mooney
    • Dec 2012
    • 1436
    There's nothing in the log file related to attempting to restart the server. The log file only shows when the server was previously shut down, after you removed fping.
    Does the command
    systemctl status -l zabbix-server.service
    show any additional information? I'm guessing it won't, because you're using the pre-systemd /etc/init.d/zabbix-server script to start and stop Zabbix, but it's worth looking at to see if there is anything more detailed there.
