HTTP Agent: Cannot add item Invalid parameter "posts": JSON is expected.
  • DPasternak
    • Sep 2021
    • 12
    I have an issue with adding HTTP Agent item. When I'm running the test, there is no problem and I can see JSON output.
    Finally, I get the string and JSON of the result by parsing the data. However, when I want to save, an error is returned to me.
    Please help me figure it out, I could not find anything on it.
    Thank you.
  • DPasternak
    • Sep 2021
    • 12
    Originally posted by cyber
    You defined that request body is JSON, but left the field empty... Set it to Raw data and you should be fine, as you actually will get back JSON, not submitting JSON...
    Thank you.
