Postgresql memory leak with LLD procesees
  • bogdar
    • Jan 2009
    • 33
    Hello!
    DB size: 29Gb on disk
    Required server performance, new values per second 286.71
    Number of items (enabled/disabled/not supported) 51521 / 75810 / 3488
    Number of triggers (enabled/disabled [problem/ok]) 5090 / 7390 [23 / 5067]
    Overal memory consumption:
    # free -m
    total used free shared buff/cache available
    Mem: 11781 6954 161 2664 4665 1869
    Swap: 0 0 0
    CONTAINER ID NAME CPU % MEM USAGE / LIMIT MEM % NET I/O BLOCK I/O PIDS
    24180b6e5435 zb-web-nginx 0.00% 506.9MiB / 1.266GiB 39.12% 2.34GB / 1.78GB 74.7MB / 24.6kB 38
    8fc4483c721a zb-server 0.00% 750.2MiB / 1.841GiB 39.80% 0B / 0B 34.4MB / 56.8kB 96
    1476713ee127 zb-postgres 0.00% 6.738GiB / 7.593GiB 88.74% 0B / 0B 7.59GB / 487GB 79
    dfd6c5944431 zb-java-gw 0.00% 180.2MiB / 11.5GiB 1.53% 0B / 0B 125MB / 0B 25
    c632fd9b5ef8 zb-snmptraps 0.00% 19.12MiB / 11.5GiB 0.16% 0B / 0B 33.1MB / 83.5kB 2
    PostgreSQL version: PostgreSQL 13.1 (Debian 13.1-1.pgdg100+1 - official image from dockerhub.
    Zabbix version:
    zabbix_server (Zabbix) 5.0.3
    Revision 146855b 24 August 2020, compilation time: Sep 8 2020 17:49:26
    While evaluating memory consumption of DB I found (using netstat and ps) that majority of memory is consumed by postgresql processes bound to lld workers (I have default
    StartLLDProcessors=2)
    ​ VIRT RES SHR CODE DATA %MEM COMMAND
    4478.8m 2.4g 151.5m 5.4m 2328.0m 21.0 postgres: zabbix zabbix 10.139.2.14(53344) idle
    4451.6m 2.4g 150.3m 5.4m 2300.8m 20.8 postgres: zabbix zabbix 10.139.2.14(53346) idle
    2109.6m 1.9g 1.9g 5.4m 17.0m 16.9 postgres: zabbix zabbix 10.139.2.14(53292) idle
    2111.4m 1.9g 1.9g 5.4m 18.8m 16.9 postgres: zabbix zabbix 10.139.2.14(53288) idle
    2109.3m 1.9g 1.9g 5.4m 16.7m 16.9 postgres: zabbix zabbix 10.139.2.14(53280) idle
    2105.4m 1.9g 1.9g 5.4m 12.8m 16.9 postgres: zabbix zabbix 10.139.2.14(53290) idle
    2094.2m 1.9g 1.9g 5.4m 1.6m 16.8 postgres: checkpointer
    2097.4m 97.0m 93.0m 5.4m 4.8m 0.8 postgres: zabbix zabbix 10.139.2.14(53276) idle
    2096.4m 89.6m 86.0m 5.4m 3.8m 0.8 postgres: zabbix zabbix 10.139.2.14(53348) idle
    2097.9m 88.2m 83.4m 5.4m 5.3m 0.7 postgres: zabbix zabbix 10.139.2.14(53240) idle
    2094.0m 82.1m 80.4m 5.4m 1.3m 0.7 postgres
    2094.2m 66.7m 65.0m 5.4m 1.5m 0.6 postgres: background writer
    ss -ntp | egrep '53344|53346'
    ESTAB 0 0 10.139.2.14:53346 10.139.2.14:5432 users("zabbix_server",pid=2320050,fd=7))
    ESTAB 0 0 10.139.2.14:5432 10.139.2.14:53346 users("postgres",pid=2320084,fd=9))
    ESTAB 0 0 10.139.2.14:5432 10.139.2.14:53344 users("postgres",pid=2320083,fd=9))
    ESTAB 0 0 10.139.2.14:53344 10.139.2.14:5432 users("zabbix_server",pid=2320049,fd=7))
    cat /proc/{2320050,2320049}/cmdline
    /usr/sbin/zabbix_server: lld worker #2 [processed 1 LLD rules, idle 5.929359 sec during 5.944900 sec]
    /usr/sbin/zabbix_server: lld worker #1 [processed 1 LLD rules, idle 5.349982 sec during 5.420240 sec]
    There is a number of templated installation with same issues: the memory used by LLD connection does not looks shared.
    DB configuration:
    max_connections= 200
    shared_buffers= 1944MB
    work_mem= 8MB
    maintenance_work_mem= 505MB
    effective_cache_size= 5870MB
    idle_in_transaction_session_timeout= 60s
    vacuum_cost_delay= 0
    vacuum_cost_page_hit= 0
    vacuum_cost_page_miss= 5
    vacuum_cost_page_dirty= 5
    vacuum_cost_limit= 200
    autovacuum_max_workers= 4
    autovacuum_naptime= 1s
    autovacuum_vacuum_threshold= 50
    autovacuum_analyze_threshold= 50
    autovacuum_vacuum_scale_factor= 0.05
    autovacuum_analyze_scale_factor= 0.05
    autovacuum_vacuum_cost_delay= 5ms
    autovacuum_vacuum_cost_limit= -1
    bgwriter_lru_multiplier= 4
    wal_level= logical
    wal_buffers= 16MB
    min_wal_size= 1GB
    max_wal_size= 4GB
    max_worker_processes= 4
    max_parallel_workers_per_gather= 2
    max_parallel_workers= 4
    max_parallel_maintenance_workers= 2
    listen_addresses= '*'
    effective_io_concurrency= 200
    default_statistics_target= 100
    checkpoint_completion_target= 0.8
    random_page_cost= 1.1
    pg_partman_bgw.interval= 10800
    shared_preload_libraries = 'pg_partman_bgw'
    enable_partition_pruning = on
    pg_partman_bgw.role = 'zabbix'
    pg_partman_bgw.dbname = 'zabbix'
    pg_partman_bgw.analyze = off
    pg_partman_bgw.jobmon = on
    At the moment I have no idea why PostgreSQL does not 'share' memory from LLD connections with other connection. Practically it means that memory consumption grows daily by 0.5-1.5Gb until OOM. I will stop one LLD process just to see if I memory leak speed will be changed.
    I appreciate any help.
