HTTP AGENT CHECK WEB API
  • jdoggy31
    • Feb 2019
    • 39
    I am trying to get some data from a Network Optix NVR (rebranded to hanwha)
    Example Path : https://192.168.1.153:7001/api/storageSpace
    Basic Auth: USER:API PASS:API
    I always get returned a 403, When I change the pass to be something non-correct I get a 401, which leads me to think auth is working.
    If I use SOAP UI to test, no issue
    if anyone can give me pointers on this I would be grateful.
  • tim.mooney
    • Dec 2012
    • 1436
    HTTP status code 403 is "Forbidden", which often means "you may have authenticated but you don't have permission to access the thing you're asking about".
    As you certain that user is authorized to access that part of the API?
    Are there web logs stored on the device, or perhaps is the device configured to send its logs to some other system?
