Received empty response from Zabbix Agent at [192.168.X.XX]. Assuming that agent agent dropped connection because of access permission.
please Help folks ....
Please try change 'DebugLevel' to 4 on zabbix_agentd.conf and check agent logs.
Atsushi, i changed the Zabbix Agent configuration file 'DebugLevel' to 4
In the Zabbix Agent log i am getting
9604:20151008:155617.711 End of send_buffer():SUCCEED
9604:20151008:155617.712 active checks #1 [idle 1 sec]
9599:20151008:155617.712 collector [processing data]
9599:20151008:155617.712 In update_cpustats()
9599:20151008:155617.712 End of update_cpustats()
9599:20151008:155617.712 collector [idle 1 sec]
9604:20151008:155618.712 In send_buffer() host:'127.0.0.1' port:10051 values:0/100
