Monitor informatica workflows in zabbix
  • mpasha06
    • Jan 2014
    • 15
    I have installed informatica in linux nodes, there are many workflows and sessions are running. Need to set monitoring into zabbix for workflows as below scenario.
    1. If workflow fails.
    2. If workflow running long.
    3. If workflow suspend.
    Please share your thoughts on this.
  • mpasha06
    • Jan 2014
    • 15
    Him
    I am having problem with the key, I think I can use the system.run key to get status of workflow by executing a workflow monitor command with it.
    • mpasha06
      • Jan 2014
      • 15
      OK, I system.run wont work here, I have a pmcmd command in see the workflow status in backend nodes.
      I have found that User parameters oprion can be use for monitor informatica workflows, looks its working fine.
      UserParameter=custom.wfloadtrending,/path/bin/pmcmd getworkflowdetails -sv infwork_DIR -d Domain_node2 -u user -p password -f DIR wf_Load_Trending | grep '[Succeeded]' | awk {'print $4'}
      will post the status.
      • Roberthc85
        • Jun 2023
        how can i set the UserParameter?
        I need to monitor PWC 10.2 in Zabbix 6.0
        3. If workflow suspend.​
