Missing LLD in Template Discovery rule for discovered hosts.
  • xxann5
    • Oct 2021
    Trying without success to have a set of hosts discovered and created with a discovery rule and a host prototype that then uses the "Chassis by IPMI" template to create the hosts and monitor the IPMI, among other things. It all works perfectly accept for the "Chassis by IPMI" trigger prototypes. I have outlined the issue in the following Jira.
    The part that really confounds me is that if i manually create the host with the same exact template (custom template than then links to other templates including the "Chassis by IPMI" template) i used with the discovery rule it all works perfectly and the "Chassis by IPMI" triggers are created just fine.
    Any help would be greatly appreciated.
    Thanks in advance!
