hello,
just set up a fresh zabbix 5.4 install on ubuntu (mate) 18.04 with ngninx 1.14.0, PHP Version 7.2.24, timescaledb-2-2.3.1, and postgresql 11.13 (full install log at the end of this post)
everything seemed to go well until after logging into the web interface for the first time after setup. the system information panel showed: zabbix server is running - no and the dreaded warning zabbix server is not running:the information displayed may not be current showed up at the bottom of the web interface (i have read through https://www.zabbix.com/forum/zabbix-...ot-be-current/ for the record)
zabbix_server.log showed:
password seemed to be entered correctly in conf files since the web installer loaded and was able to connect to the database to get to the main GUI interface. nonetheless double and triple checked DBPassword="test" in /etc/zabbix/zabbix_server.conf and $DB['PASSWORD'] = 'test'; in /var/www/html/zabbix/conf/zabbix.conf.php
then began dabbling with /etc/postgresql/11/main/pg_hba.conf which by default is
changed all the peer and md5 entries to trust for testing . this fixed the 'password authentication failed for user "zabbix"'error, the zabbix web interface loads and the server shows as running, but after a few seconds the database connection drops, with a new error in the zabbix_server.log :
the only fix was to stop the zabbix-server service, log into psql ( sudo -u postgres psql ) and drop all connections
SELECT pg_terminate_backend(pg_stat_activity.pid)
FROM pg_stat_activity
WHERE pg_stat_activity.datname = 'zabbix'
AND pid <> pg_backend_pid();
any help figuring out how to get this final config tweaked correctly is greatly appreciated.
here is the full install log if it is of use to anyone - a few things had to be tweaked from the official guide/other guides online (maybe i tweaked them wrong):
1. Install PostgreSQL 11
returns:
psql (PostgreSQL) 11.13 (Ubuntu 11.13-1.pgdg18.04+1)
2. Install TimescaleDB
3. Configure PostgresSQL
add line 617 shared_preload_libraries = 'timescaledb'
4. timescaledb-tune
Install Go (32-bit in this case - find link for x64 version at https://golang.org/dl/ if necessary)
y for correct if postgresql conf is listed correctly
y to tune memory
y to all prompts
5. Install Zabbix
entered password: test
Fix timescaledb.sql (wasn't a gz file for some reason) -
6. Edit various conf files
Line 129 Add DBPassword (needs to be in quotes)
Line 434 CacheSize=32M
uncomment and set 'listen' and 'server_name' directives.
# listen 80;
# server_name example.com;
add client_max_body_size 32M; to basic settings
line 44 add index.php
uncomment line 56, 57, 60 and 63 change php7.0 on line 60 to php7.2
# line 380
max_execution_time = 300
# line 401
memory_limit = 256M
# line 669
post_max_size = 32M
# line 822
upload_max_filesize = 32M
# line 390
max_input_time = 300
7. Enable and start services
8. Copy frontend files
9. Check and enable firewall access
10. restart all services just to make sure
sudo systemctl restart zabbix-server zabbix-agent nginx php7.2-fpm postgresql
11. Web Interface setup
Go to http://localhost/zabbix
Choose language
makes sure prerequisites are ok
Configure DB Connection
type: postgreSQL
use defaults
Zabbix server details
Set time zone and theme
connection to database 'zabbix' failed: [0] connection to server at "localhost" (127.0.0.1), port 5432 failed: FATAL: password authentication failed for user "zabbix" connection to server at "localhost" (127.0.0.1), port 5432 failed: FATAL: password authentication failed for user "zabbix"
# Database administrative login by Unix domain socket local all postgres peer # TYPE DATABASE USER ADDRESS METHOD # "local" is for Unix domain socket connections only local all all peer # IPv4 local connections: host all all 127.0.0.1/32 md5 # IPv6 local connections: host all all ::1/128 md5 # Allow replication connections from localhost, by a user with the # replication privilege. local replication all peer host replication all 127.0.0.1/32 md5 host replication all ::1/128 md5
connection to database 'zabbix' failed: [0] connection to server at "localhost" (127.0.0.1), port 5432 failed: FATAL: remaining connection slots are reserved for non-replication superuser connections
sudo apt install postgresql-common && sudo sh /usr/share/postgresql-common/pgdg/apt.postgresql.org.sh && sudo apt update sudo apt install postgresql-11 postgresql-client-11 sudo systemctl enable --now postgresql
sudo -u postgres psql -V
sudo add-apt-repository ppa:timescale/timescaledb-ppa sudo apt update sudo apt install timescaledb-2-2.3.1-postgresql-11
sudo nano /etc/postgresql/11/main/postgresql.conf
sudo systemctl restart postgresql
cd ~ wget https://golang.org/dl/go1.17.2.linux-386.tar.gz sudo tar -C /usr/local -xzf go1.17.2.linux-386.tar.gz export PATH=$PATH:/usr/local/go/bin go install github.com/timescale/timescaledb-tune/cmd/timescaledb-tune@latest cd go/bin sudo ./timescaledb-tune
y to tune memory
y to all prompts
sudo service postgresql restart
cd ~ wget https://repo.zabbix.com/zabbix/5.4/ubuntu/pool/main/z/zabbix-release/zabbix-release_5.4-1+ubuntu18.04_all.deb sudo dpkg -i zabbix-release_5.4-1+ubuntu18.04_all.deb sudo apt update sudo apt install zabbix-server-pgsql zabbix-frontend-php php7.2-pgsql zabbix-nginx-conf zabbix-sql-scripts zabbix-agent sudo -u postgres createuser --pwprompt zabbix
sudo -u postgres createdb -O zabbix zabbix sudo zcat /usr/share/doc/zabbix-sql-scripts/postgresql/create.sql.gz | sudo -u zabbix psql zabbix echo "CREATE EXTENSION IF NOT EXISTS timescaledb CASCADE;" | sudo -u postgres psql zabbix
cd /usr/share/doc/zabbix-sql-scripts/postgresql/ sudo gzip timescaledb.sql zcat /usr/share/doc/zabbix-sql-scripts/postgresql/timescaledb.sql.gz | sudo -u zabbix psql zabbix
sudo nano /etc/zabbix/zabbix_server.conf
sudo nano /etc/zabbix/nginx.conf
# listen 80;
sudo nano /etc/nginx/nginx.conf
sudo nano /etc/nginx/sites-available/default
sudo nano /etc/php/7.2/fpm/php.ini
# line 401
memory_limit = 256M
# line 669
post_max_size = 32M
# line 822
# line 390
sudo systemctl enable --now zabbix-server zabbix-agent nginx php7.2-fpm
sudo cp -pr /usr/share/zabbix /var/www/html/zabbix
sudo ufw status verbose sudo ufw allow from [ip] to any port 80
Choose language
type: postgreSQL
use defaults
