cannot link templates for auto registered hosts
  • sHaggY_caT
    • Mar 2010
    • 48
    I'm trying to use action for auto add hosts in zabbix server, and it doesn't works.
    I have an error in zabbix log:
    13896:20151010:181747.138 cannot link template(s) "Template OS Linux", "Template App Zabbix Agent", "Template SNMP Interfaces", "Template SNMP Disks", "Template SNMP OS Linux", "Template App MySQL", "Template App HTTP Service", "Template App SSH Service", "Template ICMP Ping" to host "test.***.**": conflicting item key "ifDescr" found
    How can I fix this trouble?
    Server:
    zabbix-server-2.4.6-1.el7.x86_64
    zabbix-2.4.6-1.el7.x86_64
    zabbix-server-pgsql-2.4.6-1.el7.x86_64
    zabbix-web-2.4.6-1.el7.noarch
    zabbix-web-pgsql-2.4.6-1.el7.noarch
    Client:
    zabbix-agent 1:2.4.6-1+trusty
  • kloczek
    • Jun 2006
    • 1771
    Firs please make decision how you want to monitor your Linux box .. over SNMP or over zabbix agent.
    After this choose templates.
    • incama
      • Jan 2015
      • 66
      Server:
      Client:
      I believe that the Template SNMP Interfaces and Template SNMP OS Linux are using the same item key. Each item key has to be unique per host.
