Zabbix proxy corrupting my database with 'database error'
  • GuillaumeFenollar
    • Oct 2021
    Hello everyone, and thank you for this great piece of software
    I have a Zabbix Proxy machine using SQLite3, VM running CentOS 8, x86_64. It has just replaced a Zabbix proxy machine with exactly the same hostname which used to be a bare-metal machine, not sure it's important but I prefer to mention that.
    Former proxy machine used to work like a charm. But new instance that replaced it doesn't initialize properly ; when Zabbix server try to send Proxy configuration, operation ends up with following logs :
    7763:20211025:102610.189 received configuration data from server at "192.168.128.14", datalen 8532
    7763:20211025:102610.190 [Z3005] query failed: [0] UNIQUE constraint failed: globalmacro.macro [insert into globalmacro (globalmacroid,macro,value) values (2,'{$SNMP_COMMUNITY}','public');
    insert into globalmacro (globalmacroid,macro,value) values (3,'{$IOB_NET_INT_TRUNK}','^[Tt][Rr][Uu][Nn][Kk].*');
    insert into globalmacro (globalmacroid,macro,value) values (4,'{$IOB_NET_INT_PO}','^Interface [Pp][Oo][0-9]$');
    insert into globalmacro (globalmacroid,macro,value) values (5,'{$IOB_NET_INT_DUPLEX}','.*Duplex status.*');
    insert into globalmacro (globalmacroid,macro,value) values (6,'{$IOB_NET_INT_PO_CH}','^[Pp][Oo][Rr][Tt]-[Cc][Hh][Aa][Nn][Nn][Ee][Ll][0-9.]');
    insert into globalmacro (globalmacroid,macro,value) values (7,'{$IOB_NET_INT_GI}','[Gg][Ii][0-9.].*');
    insert into globalmacro (globalmacroid,macro,value) values (8,'{$IOB_NET_INT_SUP}','^[Ss][Uu][Pp].*$');
    insert into globalmacro (globalmacroid,macro,value) values (9,'{$IF.ERRORS.WARN}','30');
    insert into globalmacro (globalmacroid,macro,value) values (10,'{$IF.UTIL.MAX}','50');
    insert into globalmacro (globalmacroid,macro,value) values (12,'{$IOB_NET_INT_GIGA}','^GigabitEthernet[0-9.].*');
    insert into globalmacro (globalmacroid,macro,value) values (13,'{$IOB_NET_INT_TUNNEL}','^Tunnel[0-9.].*');
    insert into globalmacro (globalmacroid,macro,value) values (14,'{$IF.UTIL.DUREE.MAX}','1m');
    insert into globalmacro (globalmacroid,macro,value) values (15,'{$IF.UTIL.MAX.RECOVERY}','2');
    insert into globalmacro (globalmacroid,macro,value) values (16,'{$IF.ERRORS.DUREE.WARN}','5m');
    insert into globalmacro (globalmacroid,macro,value) values (17,'{$IF.ERRORS.WARN.RECOVERY}','5');
    insert into globalmacro (globalmacroid,macro,value) values (18,'{$IOB_NET_INT_EMBED}','^[Ee]mbedded-[Ss]ervice-[Ee]ngine.*');
    insert into globalmacro (globalmacroid,macro,value) values (19,'{$IOB_NET_INT_NULL}','^[Nn]ull.*');
    insert into globalmacro (globalmacroid,macro,value) values (20,'{$IOB_NET_INT_NU}','^[Nn][Uu].*');
    insert into globalmacro (globalmacroid,macro,value) values (21,'{$IOB_NET_INT_EM}','^[Ee][Mm].*');
    insert into globalmacro (globalmacroid,macro,value) values (23,'{$IOB_NET_INT_NV}','^[Nn][Vv].*');
    insert into globalmacro (globalmacroid,macro,value) values (24,'{$IOB_NET_INT_VIR}','(24|131|135)');
    insert into globalmacro (globalmacroid,macro,value) values (26,'{$IOB_NET_INT_TYPE_1}','(1)');
    insert into globalmacro (globalmacroid,macro,value) values (27,'{$IOB_NET_INT_BRIO}','^[Bb][Rr][Ii][Oo].*');
    insert into globalmacro (globalmacroid,macro,value) values (28,'{$IOB_NET_INT_BRIO_IFNAME}','^[Bb][Rr][0-9].*');
    insert into globalmacro (globalmacroid,macro,value) values (30,'{$CPU.UTIL.CRIT}','99');
    insert into globalmacro (globalmacroid,macro,value) values (31,'{$MEMORY.UTIL.MAX}','95');
    insert into globalmacro (globalmacroid,macro,value) values (32,'{$SWAP.FREE.ALERT}','30');
    7763:20211025:102610.190 failed to update local proxy configuration copy: database error
    Of course I first tried to remove the zabbix_proxy SQLite database, I removed the file then restarted Zabbix Proxy. Same issue.
    I then retried with manual creation of SQLite database (using provided schema.sql.gz), same issue.
    I thought it could be related to the old proxy machine sharing the same name (machine removed since), so I removed all configuration for that proxy, removed again the database, then restarted && recreated the Proxy object configuration. Same issue.
    Except from trying with Postgres or Mariadb database as a workaround, I'm not sure what I can do next... The machine is supposed to monitor a bunch a agents only, so anything other than SQLite would be overkill IMO.
    It looks like a new bug. Any ideas ..?
    Thank you in advance,
    Guillaume
  • GuillaumeFenollar
    • Oct 2021
    Hello cyber, Thank you for your response
    Indeed I did not specify version, sorry for that. I had this issue on 5.0.15, and I tried downgrading to 5.0.1 without success.
    Insert in double look suspicions yes, I have no idea what can cause that.
    • GuillaumeFenollar
      • Oct 2021
      Up
      Same issue when I reset zabbix-proxy database and change hostname on Server side (Proxies conf) and host side (hostname). Same double inserts...
      • GuillaumeFenollar
        • Oct 2021
        Since it looks to be a server issue (sending double insert to this proxy), let me paste here the debug log from the server process :
        70754:20211027:095400.211 zbx_setproctitle() title:'proxy poller #1 [exchanged data with 2 proxies in 0.009213 sec, exchanging data]'
        70754:20211027:095400.211 In process_proxy()
        70754:20211027:095400.211 In DCconfig_get_proxypoller_hosts()
        70754:20211027:095400.211 End of DCconfig_get_proxypoller_hosts():1
        70754:20211027:095400.211 In substitute_simple_macros_impl() data:'10051'
        70754:20211027:095400.211 In get_proxyconfig_data() proxy_hostid:10680
        70754:20211027:095400.211 query [txnlev:1] [begin;]
        70754:20211027:095400.211 query [txnlev:1] [select hostid from hosts where proxy_hostid=10680 and status in (0,1) and flags<>2]
        70754:20211027:095400.211 query [txnlev:1] [select httptestid from httptest t,hosts h where t.hostid=h.hostid and t.status=0 and h.proxy_hostid=10680 and h.status=0]
        70754:20211027:095400.211 In get_proxyconfig_table() proxy_hostid:10680 table:'globalmacro'
        70754:20211027:095400.211 query [txnlev:1] [select t.globalmacroid,t.macro,t.value from globalmacro t order by t.globalmacroid]
        70754:20211027:095400.212 End of get_proxyconfig_table():SUCCEED
        70754:20211027:095400.212 In get_proxyconfig_table() proxy_hostid:10680 table:'hosts'
        70754:20211027:095400.212 In get_proxyconfig_table() proxy_hostid:10680 table:'interface'
        70754:20211027:095400.212 In get_proxyconfig_table() proxy_hostid:10680 table:'interface_snmp'
        70754:20211027:095400.212 In get_proxyconfig_table() proxy_hostid:10680 table:'hosts_templates'
        70754:20211027:095400.212 In get_proxyconfig_table() proxy_hostid:10680 table:'hostmacro'
        70754:20211027:095400.212 In get_proxyconfig_table_items() proxy_hostid:10680
        70754:20211027:095400.212 query [txnlev:1] [select t.itemid,t.type,t.snmp_oid,t.hostid,t.key_,t.delay ,t.status,t.value_type,t.trapper_hosts,t.logtimefm t,t.params,t.ipmi_sensor,t.authtype,t.username,t.p asswo
        rd,t.publickey,t.privatekey,t.flags,t.interfaceid, t.jmx_endpoint,t.master_itemid,t.timeout,t.url,t.q uery_fields,t.posts,t.status_codes,t.follow_redire cts,t.post_type,t.http_proxy,t.headers,t.retrieve_ mode,t.
        request_method,t.output_format,t.ssl_cert_file,t.s sl_key_file,t.ssl_key_password,t.verify_peer,t.ver ify_host,t.allow_traps from items t,hosts r where t.hostid=r.hostid and r.proxy_hostid=10680 and r.status in (0,1) and t.flags<>2 and t.type in (0,7,20,12,2,3,9,10,11,13,14,16,17,5,19,18) order by t.itemid]
        70755:20211027:095400.212 zbx_setproctitle() title:'self-monitoring [processing data]'
        70755:20211027:095400.212 In collect_selfmon_stats()
        70755:20211027:095400.212 End of collect_selfmon_stats()
        70755:20211027:095400.212 zbx_setproctitle() title:'self-monitoring [processed data in 0.000044 sec, idle 1 sec]'
        70754:20211027:095400.212 End of get_proxyconfig_table_items():SUCCEED
        70754:20211027:095400.212 In get_proxyconfig_table() proxy_hostid:10680 table:'drules'
        70754:20211027:095400.212 query [txnlev:1] [select t.druleid,t.name,t.iprange,t.delay from drules t where t.proxy_hostid=10680 and t.status=0 order by t.druleid]
        70754:20211027:095400.213 In get_proxyconfig_table() proxy_hostid:10680 table:'dchecks'
        70754:20211027:095400.213 query [txnlev:1] [select t.dcheckid,t.druleid,t.type,t.key_,t.snmp_communit y,t.ports,t.snmpv3_securityname,t.snmpv3_securityl evel,t.snmpv3_authpassphrase,t.snmpv3_privpassphra se,t.uniq,t.snmpv3_authprotocol,t.snmpv3_privproto col,t.snmpv3_contextname,t.host_source,t.name_sour ce from dchecks t,drules r where t.druleid=r.druleid and r.proxy_hostid=10680 and r.status=0 order by t.dcheckid]
        70754:20211027:095400.213 End of get_proxyconfig_table():SUCCEED
        70754:20211027:095400.213 In get_proxyconfig_table() proxy_hostid:10680 table:'regexps'
        70754:20211027:095400.213 query [txnlev:1] [select t.regexpid,t.name from regexps t order by t.regexpid]
        70754:20211027:095400.213 In get_proxyconfig_table() proxy_hostid:10680 table:'expressions'
        70754:20211027:095400.213 query [txnlev:1] [select t.expressionid,t.regexpid,t.expression,t.expressio n_type,t.exp_delimiter,t.case_sensitive from expressions t order by t.expressionid]
        70754:20211027:095400.213 In get_proxyconfig_table() proxy_hostid:10680 table:'hstgrp'
        70754:20211027:095400.213 query [txnlev:1] [select t.groupid from hstgrp t,config r where t.groupid=r.discovery_groupid order by t.groupid]
        70754:20211027:095400.213 In get_proxyconfig_table() proxy_hostid:10680 table:'config'
        70754:20211027:095400.213 query [txnlev:1] [select t.configid,t.refresh_unsupported,t.discovery_group id,t.snmptrap_logging,t.autoreg_tls_accept from config t order by t.configid]
        70754:20211027:095400.213 In get_proxyconfig_table() proxy_hostid:10680 table:'httptest'
        70754:20211027:095400.213 In get_proxyconfig_table() proxy_hostid:10680 table:'httptestitem'
        70754:20211027:095400.213 In get_proxyconfig_table() proxy_hostid:10680 table:'httptest_field'
        70754:20211027:095400.214 In get_proxyconfig_table() proxy_hostid:10680 table:'httpstep'
        70754:20211027:095400.214 End of get_proxyconfig_table():SUCCEED
        70754:20211027:095400.214 In get_proxyconfig_table() proxy_hostid:10680 table:'httpstepitem'
        70754:20211027:095400.214 In get_proxyconfig_table() proxy_hostid:10680 table:'httpstep_field'
        70754:20211027:095400.214 In get_proxyconfig_table() proxy_hostid:10680 table:'config_autoreg_tls'
        70754:20211027:095400.214 query [txnlev:1] [select t.autoreg_tlsid,t.tls_psk_identity,t.tls_psk from config_autoreg_tls t order by t.autoreg_tlsid]
        70754:20211027:095400.214 query [txnlev:1] [commit;]
        70754:20211027:095400.214 End of get_proxyconfig_data():SUCCEED
        70754:20211027:095400.214 In connect_to_proxy() address:192.168.128.220 port:10051 timeout:300 conn:1
        70754:20211027:095400.215 End of connect_to_proxy():SUCCEED
        70754:20211027:095400.215 sending configuration data to proxy "*********" at "192.168.128.220", datalen 8532
        70754:20211027:095400.215 In send_data_to_proxy() data:'{"request":"proxy config","data":{"globalmacro":{"fields":["globalmacroid","macro","value"],"data":[[2,"{$SNMP_COMMUNITY}","public"],[2,"{$SNMP_COMMUNITY}","public"],[3,"{$IOB_NET_INT_TRUNK}","^[Tt][Rr][Uu][Nn][Kk].*"],[3,"{$IOB_NET_INT_TRUNK}","^[Tt][Rr][Uu][Nn][Kk].*"],[4,"{$IOB_NET_INT_PO}","^Interface [Pp][Oo][0-9]$"],[4,"{$IOB_NET_INT_PO}","^Interface [Pp][Oo][0-9]$"],[5,"{$IOB_NET_INT_DUPLEX}",".*Duplex status.*"],[5,"{$IOB_NET_INT_DUPLEX}",".*Duplex status.*"],[6,"{$IOB_NET_INT_PO_CH}","^[Pp][Oo][Rr][Tt]-[Cc][Hh][Aa][Nn][Nn][Ee][Ll][0-9.]"],[6,"{$IOB_NET_INT_PO_CH}","^[Pp][Oo][Rr][Tt]-[Cc][Hh][Aa][Nn][Nn][Ee][Ll][0-9.]"],[7,"{$IOB_NET_INT_GI}","[Gg][Ii][0-9.].*"],[7,"{$IOB_NET_INT_GI}","[Gg][Ii][0-9.].*"],[8,"{$IOB_NET_INT_SUP}","^[Ss][Uu][Pp].*$"],[8,"{$IOB_NET_INT_SUP}","^[Ss][Uu][Pp].*$"],[9,"{$IF.ERRORS.WARN}","30"],[9,"{$IF.ERRORS.WARN}","30"],[10,"{$IF.UTIL.MAX}","50"],[10,"{$IF.UTIL.MAX}","50"],[12,"{$IOB_NET_INT_GIGA}","^GigabitEthernet[0-9.].*"],[12,"{$IOB_NET_INT_GIGA}","^GigabitEthernet[0-9.].*"],[13,"{$IOB_NET_INT_TUNNEL}","^Tunnel[0-9.].*"],[13,"{$IOB_NET_INT_TUNNEL}","^Tunnel[0-9.].*"],[14,"{$IF.UTIL.DUREE.MAX}","1m"],[14,"{$IF.UTIL.DUREE.MAX}","1m"],[15,"{$IF.UTIL.MAX.RECOVERY}","2"],[15,"{$IF.UTIL.MAX.RECOVERY}","2"],[16,"{$IF.ERRORS.DUREE.WARN}","5m"],[16,"{$IF.ERRORS.DUREE.WARN}","5m"],[17,"{$IF.ERRORS.WARN.RECOVERY}","5"],[17,"{$IF.ERRORS.WARN.RECOVERY}","5"],[18,"{$IOB_NET_INT_EMBED}","^[Ee]mbedded-[Ss]ervice-[Ee]ngine.*"],[18,"{$IOB_NET_INT_EMBED}","^[Ee]mbedded-[Ss]ervice-[Ee]ngine.*"],[19,"{$IOB_NET_INT_NULL}","^[Nn]ull.*"],[19,"{$IOB_NET_INT_NULL}","^[Nn]ull.*"],[20,"{$IOB_NET_INT_NU}","^[Nn][Uu].*"],[20,"{$IOB_NET_INT_NU}","^[Nn][Uu].*"],[21,"{$IOB_NET_INT_EM}","^[Ee][Mm].*"],[21,"{$IOB_NET_INT_EM}","^[Ee][Mm].*"],[23,"{$IOB_NET_INT_NV}","^[Nn][Vv].*"],[23,"{$IOB_NET_INT_NV}","^[Nn][Vv].*"],[24,"{$IOB_NET_INT_VIR}","(24|131|135)"],[24,"{$IOB_NET_INT_VIR}","(24|131|135)"],[26,"{$IOB_NET_INT_TYPE_1}","(1)"],[26,"{$IOB_NET_INT_TYPE_1}","(1)"],[27,"{$IOB_NET_INT_BRIO}","^[Bb][Rr][Ii][Oo].*"],[27,"{$IOB_NET_INT_BRIO}","^[Bb][Rr][Ii][Oo].*"],[28,"{$IOB_NET_INT_BRIO_IFNAME}","^[Bb][Rr][0-9].*"],[28,"{$IOB_NET_INT_BRIO_IFNAME}","^[Bb][Rr][0-9].*"],[30,"{$CPU.UTIL.CRIT}","99"],[30,"{$CPU.UTIL.CRIT}","99"],[31,"{$MEMORY.UTIL.MAX}","95"],[31,"{$MEMORY.UTIL.MAX}","95"],[32,"{$SWAP.FREE.ALERT}","30"],[32,"{$SWAP.FREE.ALERT}","30"]]},"hosts":{"fields":["hostid","host","status","available","ipmi_authtyp e","ipmi_privilege","ipmi_username","ipmi_password ","ipmi_available","snmp_available","jmx_available ","name","tls_connect","tls_accept","tls_issuer"," tls_subject","tls_psk_identity","tls_psk"],"data":[]},"interface":{"fields":["interfaceid","hostid","main","type","useip","ip", "dns","port"],"data":[]},"interface_snmp":{"fields":["interfaceid","version","bulk","community","securi tyname","securitylevel","authpassphrase","privpass phrase","authprotocol","privprotocol","contextname "],"data":[]},"hosts_templates":{"fields":["hosttemplateid","hostid","templateid"],"data":[]},"hostmacro":{"fields":["hostmacroid","hostid","macro","value"],"data":[]},"items":{"fields":["itemid","type","snmp_oid","hostid","key_","delay" ,"status","value_type","trapper_hosts","logtimefmt ","params","ipmi_sensor","authtype","username","pa ssword","publickey","privatekey","flags","interfac eid","jmx_endpoint","master_itemid","timeout","url ","query_fields","posts","status_codes","follow_re directs","post_type","http_proxy","headers","retri eve_mode","request_method","output_format","ssl_ce rt_file","ssl_key_file","ssl_key_password","verify _peer","verify_host","allow_traps"],"data":[]},"drules":{"fields":["druleid","name","iprange","delay"],"data":[]},"dchecks":{"fields":["dcheckid","druleid","type","key_","snmp_community ","ports","snmpv3_securityname","snmpv3_securityle vel","snmpv3_authpassphrase","snmpv3_privpassphras e","uniq","snmpv3_authprotocol","snmpv3_privprotoc ol","snmpv3_contextname","host_source","name_sourc e"],"data":[]},"regexps":{"fields":["regexpid","name"],"data":[[1,"File systems for discovery"],[2,"Network interfaces for discovery"],[3,"Storage devices for SNMP discovery"],[4,"Windows service names for discovery"],[5,"Windows service startup states for discovery"],[6,"Network Interface for Discovery ALIAS Trunk"],[8,"Network Interface Discover Po"],[9,"Network Interface for Discovery Not DUPLEX"],[10,"Network Interface PO Discover"],[11,"Network Interface Gi Discovery"],[12,"Network Interface Discover ALIAS SUP"],[13,"Network Interface GigabitEthernet"],[14,"Network Interface Tunnel"],[15,"Network Interface Embedded-Service-Engine"],[16,"Network Interface Null0"],[17,"Network Interface GigabitEthernet Virtual"],[18,"Network Interface GigabitEthernet long"],[19,"Interface Virtuel Iftype"],[20,"Interface BRIO"],[21,"Interface BRIO IFNAME"],[22,"TESTE CSCB | SF2i"]]},"expressions":{"fields":["expressionid","regexpid","expression","expression _type","exp_delimiter","case_sensitive"],"data":[[1,1,"^(btrfs|ext2|ext3|ext4|reiser|xfs|ffs|ufs|jfs |jfs2|vxfs|hfs|apfs|refs|ntfs|fat32|zfs)$",3,",",0],[1,1,"^(btrfs|ext2|ext3|ext4|reiser|xfs|ffs|ufs|jfs |jfs2|vxfs|hfs|apfs|refs|ntfs|fat32|zfs)$",3,",",0],[3,3,"^(Physical memory|Virtual memory|Memory buffers|Cached memory|Swap space)$",4,",",1],[3,3,"^(Physical memory|Virtual memory|Memory buffers|Cached memory|Swap space)$",4,",",1],[5,4,"^(MMCSS|gupdate|SysmonLog|clr_optimization_v2 .0.50727_32|clr_optimization_v4.0.30319_32)$",4,", ",1],[5,4,"^(MMCSS|gupdate|SysmonLog|clr_optimization_v2 .0.50727_32|clr_optimization_v4.0.30319_32)$",4,", ",1],[6,5,"^(automatic|automatic delayed)$",3,",",1],[6,5,"^(automatic|automatic delayed)$",3,",",1],[7,2,"^Software Loopback Interface",4,",",1],[7,2,"^Software Loopback Interface",4,",",1],[8,2,"^(In)?[Ll]oop[Bb]ack[0-9._]*$",4,",",1],[8,2,"^(In)?[Ll]oop[Bb]ack[0-9._]*$",4,",",1],[9,2,"^NULL[0-9.]*$",4,",",1],[9,2,"^NULL[0-9.]*$",4,",",1],[10,2,"^[Ll]o[0-9.]*$",4,",",1],[10,2,"^[Ll]o[0-9.]*$",4,",",1],[11,2,"^[Ss]ystem$",4,",",1],[11,2,"^[Ss]ystem$",4,",",1],[12,2,"^Nu[0-9.]*$",4,",",1],[12,2,"^Nu[0-9.]*$",4,",",1],[13,6,"^[Tt][Rr][Uu][Nn][Kk].*",3,",",1],[13,6,"^[Tt][Rr][Uu][Nn][Kk].*",3,",",1],[17,6,"[.*]",4,",",0],[17,6,"[.*]",4,",",0],[18,8,"^Interface [Pp][Oo][0-9]$",3,",",0],[18,8,"^Interface [Pp][Oo][0-9]$",3,",",0],[19,9,".*Duplex status.*",3,",",0],[19,9,".*Duplex status.*",3,",",0],[20,10,"^[Pp][Oo][Rr][Tt]-[Cc][Hh][Aa][Nn][Nn][Ee][Ll][0-9.]",3,",",0],[20,10,"^[Pp][Oo][Rr][Tt]-[Cc][Hh][Aa][Nn][Nn][Ee][Ll][0-9.]",3,",",0],[21,11,"[Gg][Ii][0-9.].*",3,",",0],[21,11,"[Gg][Ii][0-9.].*",3,",",0],[22,12,"^[Ss][Uu][Pp].*$",3,",",0],[22,12,"^[Ss][Uu][Pp].*$",3,",",0],[23,13,"GigabitEthernet\\d{10}",3,",",0],[23,13,"GigabitEthernet\\d{10}",3,",",0],[24,14,"^Tunnel[0-9.].*",3,",",0],[24,14,"^Tunnel[0-9.].*",3,",",0],[25,15,"^[Ee]mbedded-[Ss]ervice-[Ee]ngine.*",3,",",0],[25,15,"^[Ee]mbedded-[Ss]ervice-[Ee]ngine.*",3,",",0],[26,16,"^[Nn]ull.*",3,",",0],[26,16,"^[Nn]ull.*",3,",",0],[27,17,"^GigabitEthernet[0-9.]/.*[.][0-9.].*$",3,",",0],[27,17,"^GigabitEthernet[0-9.]/.*[.][0-9.].*$",3,",",0],[28,18,"^GigabitEthernet[0-9.]/[0-9.]/[0-9.0-9]$",3,",",0],[28,18,"^GigabitEthernet[0-9.]/[0-9.]/[0-9.0-9]$",3,",",0],[29,19,"(24|131|135)",0,",",0],[29,19,"(24|131|135)",0,",",0],[30,20,"^[Bb][Rr][Ii][Oo].*",3,",",0],[30,20,"^[Bb][Rr][Ii][Oo].*",3,",",0],[31,21,"^[Bb][Rr][0-9].*",3,",",0],[31,21,"^[Bb][Rr][0-9].*",3,",",0],[32,22,"AC.1C.E7.05",4,",",0],[32,22,"AC.1C.E7.05",4,",",0]]},"hstgrp":{"fields":["groupid"],"data":[[5],[5]]},"config":{"fields":["configid","refresh_unsupported","discovery_groupi d","snmptrap_logging","autoreg_tls_accept"],"data":[[1,"10m",5,1,1],[1,"10m",5,1,1]]},"httptest":{"fields":["httptestid","name","delay","agent","authenticatio n","http_user","http_password","hostid","http_prox y","retries","ssl_cert_file","ssl_key_file","ssl_k ey_password","verify_peer","verify_host"],"data":[]},"httptestitem":{"fields":["httptestitemid","httptestid","itemid","type"],"data":[]},"httptest_field":{"fields":["httptest_fieldid","httptestid","type","name","val ue"],"data":[]},"httpstep":{"fields":["httpstepid","httptestid","name","no","url","timeo ut","posts","required","status_codes","follow_redi rects","retrieve_mode","post_type"],"data":[]},"httpstepitem":{"fields":["httpstepitemid","httpstepid","itemid","type"],"data":[]},"httpstep_field":{"fields":["httpstep_fieldid","httpstepid","type","name","val ue"],"data":[]},"config_autoreg_tls":{"fields":["autoreg_tlsid","tls_psk_identity","tls_psk"],"data":[[1,"",""],[1,"",""]]}}}'
        70754:20211027:095400.215 End of send_data_to_proxy():SUCCEED
        70754:20211027:095400.215 In zbx_recv_response()
        Hope it can help debugging
        • GuillaumeFenollar
          • Oct 2021
          Bump
          Since it's a real bug that , in my opinion, should be investigated, is there another place I should report it ?
          • GuillaumeFenollar
            • Oct 2021
            Actually this is worst than I thought. All my zabbix proxies are having this issue, and not only this one.
            All the 4 proxies continue working but with the old configuration, so any configuration change is not taken into account for 5 days now, this is pretty serious.
            If you have any idea so the company doesn't throw away the whole Zabbix infra (202 hosts / 12k items), I'm eager to ear it
            • tim.mooney
              • Dec 2012
              • 1437
              In your original post, you said that you had replaced one proxy with a proxy on a VM, and that's when the issue started.
              Have you replaced all your proxies? What else changed 5 days ago that might be related to all of your proxies breaking?
              • GuillaumeFenollar
                • Oct 2021
                Hi Tim,
                Indeed, on monday, I reinstalled a centos machine for replacing a base metal machine with a virtual machine. I kept the same proxy configuration on server (same machine name/IP) and that's all, I don't remember about any other configuration change except templates/items/triggers stuff.
                Have a good Day,
                • GuillaumeFenollar
                  • Oct 2021
                  Up!
                  I'm realizing now there's a special "Troubleshooting" forum here, that thread should be there.
                  In the meantime, I've opened an issue on Jira for following this problem : https://support.zabbix.com/browse/ZBX-20172
                    • 5004
                    What version of Zabbix? All lines seem to be double... I am not much of a DB person, but that should cause some issues with UNIQUE...
