Issue with a graph
  • cnsops
    • Oct 2021
    Issue with a graph
    I have been having some problems with my Zabbix for a while.
    I have two hosts configured in the same way but they don't show the graphs in the same way.
    The 001 node seems to have a problem and returns one on two value at 0.
    Would you have any clue about this problem?
ID:	433701Click image for larger version
  • Atsushi
    • Aug 2013
    • 2028
    Check the process on 001 node. You may be able to identify the cause by using the top command to find the processes that are running a lot.
    • cnsops
      • Oct 2021
      Hi !
      No problem on the process for node 001, only the graph that appears jagged on Zabbix.
      The graph returns one on two value at 0, which is not the case on the server with the top command.
      • cnsops
        • Oct 2021
        Hi guys,
        Any idea ?
