Modifying the pre-built System Performance dashboard - Windows agent
  • dmwcode
    • Oct 2021
    When going to Monitoring \ Hosts \ Dashboards there is a Network Interfaces and a System Performance dashboard. The System Performance only displays disk information for the C drive. I'd love to be able clone the template and modify to include any fixed disks a host has or add it to the existing template. I can't find where the dashboard is getting the settings from though. I looked under Configuration \ Templates under any Windows templates that have dashboard but could not find it. Is it possible to clone or modify this dashboard and then apply to a host group?
