web.certificate.get & inconsisten result
  • ramoneastral
    • Feb 2017
    • 33
    hi all ,
    i build my own template before i found the zbx template on git for this plugin to check details of the cert on ssl connection.
    in general it works fine as i am looking mainly for "not_after":{"value":"Sep .... value
    i have found some inconsistency in the field / value "result":{"value":"invalid" of the json.
    we run wildcards on some servers , to these are all the same certs. checking the "serial_number" is the same , string for "issuer" is the same.
    nevertheless at some host , presenting the cert, zabbix will result into "result":{"value":"invalid","message":"failed to verify certificate: x509: certificate signed by unknown authority"},
    other host have a result of valid ...
    any idea why ?
    does the plugin consider any timout settings (of the agent config ??? )
    which CA stores are considered during the evaluation of the cert ? OS of the client ? Static ones compiled into the plugin ?
    thx
